    Intersections getting too complex to work with
    3 Posts 2 Posters 277 Views 2 Watching
      monkipa
      hi all
      i need to build this out of ply and i need to define the inner space when i use sheets of 21mm thick, to define the underlying construction.i start with pushing all the faces to a 21mm thickness. all the overlapping bits i need to get rid of. the result should be that the angle between the sheets are halfed: 90° gives two cuts of 45° etc. with shapes following the axes this is easy but in this case, were no angle is the same/following the axes i am getting totally lost. . .
      would there be a helpfull plugin? is it just monks work and a matter of patience?
      i allready have a plugin that immediately tells me the angle between two faces, it has the poetic name 'angle between faces'
      i could do with some tips here. anything is greatly appreciated
      model is called Red Snail in the 3dwh.
        Have you tried Joint Push/Pull? Correct the face orientation first so all the back faces are inside.n Then you should be able to pull off the faces and make individual components of each of them.
          monkipa
          Thanks a lot that seems to work! great help!
