    Help with IF function
    6 Posts 3 Posters 2.0k Views 3 Watching
      twdant
      I understand how to use the IF function, but I'm having trouble figuring out how to produce the required TRUE value for the first IF argument.
      I need a formula that will return a TRUE value if the COPY attribute of a repeating subcomponent is equal to a certain number. Is there a function that will give me a TRUE value if two attributes are equivalent?
        Jim
        So for an attribute named "Value"
        Value: =IF(COPY = 2, TRUE, FALSE)
        will return TRUE if COPY i equal to 2 and FALSE otherwise. Have I misunderstood the question?
          Jim
          There is no == double-equal comparison operator in Dynamic Components. It is just =
          http://help.sketchup.com/en/article/114563
          (There should be < and <= on the linked page.)
          • P Offline
            pgarmyn
            Answered too fast, without reading completely.... sorry..
            • P Offline
              pgarmyn
              Wrong answer :
              %(#999999)[Maybee it should be (?):
              Value=IF(COPY == 2, TRUE, FALSE)
              But this will also work (shorter=better?) :
              Value=(COPY == 2)]
              Correction : this is for ruby, not for dynamic components
              • P Offline
                pgarmyn
                Wrong answer :
                value1==value2 will return TRUE or FALSE
                Correction : this was for ruby, not for dynamic components
