    Layout File Size Does Not Reduce When Deleting Pages
    layout
    3 Posts 2 Posters 1.3k Views 2 Watching
    • F
      fcborik
      Hello,
      I was working with a rather large Layout file (136K) and decided to break it up into sections with the intent of assembling the final document by combining PDF files in Adobe. So, the way I did this was to open the master Layout file, "save as", and then delete the unwanted pages. This process was iterated several times, one for each file that I wanted to keep. Alas, now EACH of the new files is --- 136K! I'm obviously missing something and any help would be sincerely appreciated.
      Many thanks!
      Frank Borik
      • F
        fcborik
        OK, I figured this out. File->Document Set-up->References->Purge.
        Just needed to keep with it!
        Thanks!
          Good on you, Frank.
          Just as in SketchUp, you have to purge out the unused stuff once in awhile.
