Git for SketchUcation?
@thomthom said:
...now, if there was a "Push to Publish" feature...
This.
Git linked to the pluginstore would be awesome.
@thomthom said:
The advantage of GitHub is that "everyone" is there already[β¦]
I agree with thomthom. If I was a fish, why should I make the jump from the ocean into a pond?
I don't see so enough activity on github projects that it's worth the effort to migrate them once here once there. Wouldn't it do it if we just improve the linkings between SCF and code hosting sites (and everyone can enjoy there prefered code hoster, including bit bucket). Maybe a "source code" tab in the plugins store (next to "documentation" and "release notes").
And and improved and visible button for issue reporting. Users still abuse ratings to "report" something. This is extremely demotivating and unthankful to the developer, and the developer still has no clue what is wrong. I delete (and have deleted) plugins if users don't appreciate the work.
On the other side, if it was possible for users to use an issue tracker without registering an extra account somewhere then there would be a remarkable advantage.
And automatic building, packaging and publishing etc.
The bug reporting is being worked on. We just need to figure out some of the details before testing.
It will be a process through which you (the dev) will see the bug submissions on the dashboard and the members can flag posts as bugs on the forums. Unflagging will also be possible.
Users can also flag a bug through the plugin and submit some text.
We need some method where the dev doesn't need to read 3 pages of posts just to find that one post that has a bug.
the ratings system was an experiment on our side. we needed to see how proactive users were with microtransactions.
there's a very good chance we will retire it to the site only for v3.0 of the pluginstore.
we are definitely listening to all the suggestions here. if there's things you want to happen let us know as we entering into knuckle down time soon.
if you want to play an active roll in v3.0 let us know.
Register LoginAdvertisement
