    Toolbar Oddities
    7 Posts 6 Posters 577 Views 6 Watching
    • K
      KrisM
      Whenever I start 2014 Pro, the large toolbar is placed slightly below the top horizontal toolbars. I move it up and it stays put. When I start 2014 again it is moved slightly lower. Not an earth shaking problem but annoying nonetheless. Has anyone else noticed this behavior?
      Kris
      • mitcorbM
        mitcorb
        Yes on your question.
        Have you noticed a delay in loading? White work space for about 5 seconds? The toolbar and menu frame are displayed but not the work area.
        • charly2008C
          charly2008
          I had the problem with the White space also. I suspected the problem is with a plugin. After I had deactivated !SketchUcation_loader.rb the problem was solved.
            This has been a thing since the beginning with SU2014. It is odd that the native toolbar(s) won't stay pushed up to the top. I got around the wasted real estate by sticking in a couple of single button toolbars thusly:
            I don't know why disabling the Sketchucation Loader would change the behavior. It happened for me before installing the Sketchucation Plugin Store.
            • K
              KrisM
              I get the white space lag but assumed SU was loading the plugin toolbars before painting the screen. I never considered it a problem. I rearranged my toolbars without the double wide large toolbar so the niggling gap is gone. I find it curious that I don't have any toolbar issues in any other program I'm using. SU seems to have achieved a unique status in this regard.
              Kris
              • A
                Aerilius
                The creation and display of toolbars depends for example on reading the program's configurations (SketchUp allows showing/hiding) etc., so the whole process might differ from one program to another even if they use the same type of toolbars. Also programs might use different totally user interface toolkits.
                • cottyC
                  cotty
                  These two are anyway more important than the lower... 😉
                  my SketchUp gallery
