    Internet explorer.
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    8 Posts 3 Posters 8.0k Views 3 Watching
      Are there any moves at present to fix the forum visibility levels in ie? It has been mentioned but a month or so later and nothing appears to have changed.
      • Rich O BrienR Online
        if your on ie 8 or below then you should upgrade your browser.
        if your on higher what is the issue?
          I am on ie 9 and cannot see all of the text properly.
          Heading and some other text poorly integrated.
            Can you upgrade to ie11?
            • dukejazzD Offline
              dukejazz
              I will need to buy a new machine for that, ie9 max my machine out
              Maybe in two years, saving is kind of slow right now. for this to happen.
              • dukejazzD Offline
                dukejazz
                I am on ie 9 and cannot see all of the text properly also
                I can't get these light gray on white to the buttoms
                just on this forum this happens started when you changed last the format
                  ok, there's a gradient issue in our css that doesn't support ie9 and below.
                  I've a flag raised to tackle this on Monday.
                  If you guys see other strangeness post it here so i can track the probs.
                  thanks
                    Thanks Rich.
