    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 108.9k Views 41 Watching
    • deaneauD Offline
      deaneau
      Hello Christina, hello ERS Fans (Eneroth Railroad System Fans)
      what do you think about an IdeaPool for ERS?
      my feeling is, that i overburden Christina with my ideas and wishes,
      now i have find out that some features doesn´t work in 0.1.13 .
      have ruby the function to report what i do?
      what is the best way for the developer to find out whats happend.
      checklist?
      video/movie?
      ruby analyser (?)?
      error popup?
      have sketchucation a project portal?
      normally the developer is the project leader.
      than could the developer invite some friendly other developer to look at the problem to help. some problems can´t solve one person alone.
      next level for the project bugreports with ticket.
      the user send the bugreport... the project portal make a timestamp with consecutive number like this [_2014.07.27_10h36m54s_015_00800]
      i will say it again. ERS have a big potential.
      the base is: move an object from A to B. A to C along a path etc.
      change speed, direction, appearance etc
      objects can be: all what you can build or import in sketchup.
      locos (Engines), FreightCars, PassengerCars etc.
      Aircraft/Airplane,Boats, Ships, Animals.
      _2014.07.27_11h29m03s_018_00897.wmv
      objects can have: subobjects, subobjects can be animated...
      Extrusion Profiles can be: Track, Bridges,Channels (waterway), Airway, Streets, Highway, Elevators/Lifts etc.
      Objects and Extrusion Profiles must have lowpoly design. e.g. ("exempli gratia") default track. for more information look in the wounderful manual.
      b.r. dean
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • deaneauD Offline
        deaneau
        @eneroth3 said:
        Dean,
        I have no idea what you got the things about bug fixes not working on different platforms, comparing files, uninstall, deactivate plugins and all that from. Everything indicated it was the same bug on both platform and I've found a fix for it that should work unless there are more separate bugs in the code.
        oh i have learn HTML 1996 and the big problem was the different OS (PC/MAC) and different Browsers. yes i know we have now 2014 and the globe have forward rotated ins this time. any bad feeling from this time, i can´t loose out of my head.
        An Architecture have said to me, some times it´s faster and cheap/less expansive you begin on this point before the problem was appear.
        make old building to a new building is cheaper than a new try.(some times)
        i see what you will tell me between the line. 😉Dean you have not the faintest idea.
        could be you are right. "be or not to be this is the question" 😉
        @eneroth3 said:
        The balise is for now only a technical feature for running code and has nothing to do with the physical model. I chose that name because it best described something on the track that makes something happen when some train runs by it. I've thought about extending this feature to include something that is drawn to the model, either a signal or an actual balise, but that's for the future. In that case I also rename the feature "Balise/Signal" or something similar and it will still be possible to not show it at all because it doesn't make sense to have a balise on the track or a signal next to it that paints trains.
        Ok i understand, Balise isn´t the right word for you.
        here a dictionary for the right word and the right meaning (railroad related)at page 24 first word.
        http://www.era.europa.eu/Document-Register/Documents/Glossary%20of%20railway%20terminology-selection-%20EN-FR-DE.pdf.pdf
        @eneroth3 said:
        The documentation has lots of examples that can be used in balises without being a programmer. Just copy and paste it. You can also read the balise code in the example model by double clicking on a balise with the balise tool open.
        yes i know christina, i have read your good manual 3-times. i have had hope the balise is this what it is. no problem, trigger or switcher could be the right word.
        was/is your daddy a railroader or a modelrailroader? for me i see not a difference( some MRR have more knowledge than the RR).
        all clarity eleminated?
        best regards dean
        • deaneauD Offline
          deaneau
          @eneroth3 said:
          My dad is a model railroader. Mostly Märklin H0 and Z.
          Ah ok, what do you think about contacting the producer to have the right measure for Models like märklin, roco, fleischmann, mehano, piko etc.
          kids could be design the own tabletop and scale this down to the right scale.
          an extra plugin or feature in this plugin could kids help to do this.
          yes i know with the tape measure tool in sketchup you can do this, only a little problem
          1435mm / 87 = 16,49425287356322 and the real gauge in mm is 16,5mm (this is round up
          Z-Scale
          1435mm /220 = 6,522727272727273mm real gauge 6,5mm (this is round down)
          many MRR (model rail roader)
          build the own buildings, and railroad infrastructure.
          some have a 3d printer and make this. or have a 2d printer and print out a papercraft and gluing this. sometimes with texture,too or as painter with paint-brush etc.
          you see your plugin have a big possiblity, for all railroader ( model, simulator or real)
          dean
          • eneroth3E Offline
            eneroth3
            @jonb42 said:
            Speaking of model railways I'd appreciate the option to choose scale when placing track / stock. Model railways are for the most part scale models and therefore you shouldn't have to do anything that different for them except scale... At least for me:)
            In specific I used to have model trains mostly of the Hornby 00 scale which is 1:76 according to Wikipedia though I also had a small set of 000 (1:152) and some O (1:43.5). For the animation I want to do I'd like to use something close to the 0 scale.
            Simple enough to scale it myself after creation of course however easier to route track through an existing model if it is already a scale that makes sense therein.
            • Jon
            I think it would be quite complicated to implement. There would need to be either scale inputs in all drawing tools or a new dialog for model info to definite in for the whole model. Also if the tools scale what they add the other models containing track types and rolling stock always needs to be at full scale which isn't user intuitive when the railroad model isn't. Lastly a few values have been hard coded into the plugin such as the height of the coupling symbol over the track in coupling tool.
            I think it would be easier to scale up the model railway and draw everything at full scale in SU. This also has the advantage that you don't need to rescale the whole model if you decide to have it in another scale in real life.
            I feel more burden by ideas to administrate everything 😲 . Why not just write it directly in this thread and not make it more complicated than that?
            My website: http://julia-christina-eneroth.se/
            • deaneauD Offline
              deaneau
              @eneroth3
              ok
              @jonb42
              is simple:
              build your loco 1:1
              than
              draw a line 1435mm
              groop loco and line
              use the tape measure tool
              pick the first point of the line
              go to the second point and click
              enter your targed gauge in measurements (left below)
              this scale down the scene.
              if you only want scale down the loco and other object 1:1
              do this
              build your loco 1:1
              than
              draw a line 1435mm
              groop loco and line
              GROOP AGAIN
              go in the groop (double click)
              be happy
              if you need pictures or movie let me now
              regards dean
              • eneroth3E Offline
                eneroth3
                @deaneau said:
                @eneroth3
                ok
                @jonb42
                is simple:
                build your loco 1:1
                than
                draw a line 1435mm
                groop loco and line
                do this
                build your loco 1:1
                than
                draw a line 1435mm
                groop loco and line
                GROOP AGAIN
                be happy
                regards dean
                This cannot be done on rolling stocks that are already initialized such as those in the rolling stock library. The scale would be reset when driving. Also it won't work on tracks. Scaling tracks with the scale tool changes the path they are drawn to and is used when you for instance want to change the radius or the length. The track is then redrawn with the same guage as before.
                • deaneauD Offline
                  deaneau
                  ok this mean if the loco is build in 1:1 Scale and saved in the library scaling doesnt work
                  if i design a H0 extrusion-profil (16,5mm) and build the loco in H0 scale and than save to the library this will work. right?
                  hm, than have a model loco the same speed like a real loco. m/s. wow 😮
                  next
                  what about a field to insert a radius.
                  i have try to measure the radius for 10° and 20° curves. and when i calculate this with the rule of 3 i will have different results.
                  is this a calculation error by sketchup or by the plugin?
                  the real railroad in europe measure a curved track in Radius
                  404 Not Found
                  (www.dybas.de)
                  the picture mean. the car can drive minimum this curve radius or higher.
                  • eneroth3E Offline
                    eneroth3
                    You can draw the locomotive at any size but then only use it at that size. Duplicating the same rolling stocks for different scales really isn't the right way to go. Also the slider in the drive dialog would be wrong unless the plugin doesn't know the scale and can adapt to it. The same goes for arrows in the switch tool and add rolling stock tool. I think it's easiest to draw in full scale in Sketchup. After all a model railroad is also a model representing the real world (or at least an imaginary part of it) which is in full scale.
                    • deaneauD Offline
                      deaneau
                      Hello i quick info about an exportplugin to a game...
                      look here
                      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=58665%26amp;p=533934#p533934
                      • eneroth3E Offline
                        eneroth3
                        Version 0.1.14 is out!
                        There are a few new features. The biggest is probably that tracks has been split into the actual track and the structures to place along the track. this means that there are more combinations of tracks and structures but also that there can be several structures at the same place, e.g. a bridge and a platform alongside the track. Or a platform at each side.
                        The old track types with structures built in are no longer shipped with the extension. You may want to remove these from the "Tracks/" subfolder in the plugin's folder before updating to get a cleaner track list. However that also prevents you from redrawing existing tracks of those types in the model unless you change the track type and add the structure separately.
                        The signal system has also been updated and users can now create their own signals quite easily. There's also an option in Add Track tool and Track properties not to have any signals at all.
                        Tracks with signals need to be fully redrawn to utilize the new signal system. This can be done manually by clicking them with the Track Position tool and go back (Esc or Enter) without changing their control points.
                        Lastly the Track properties dialog now supports multiple tracks at once. This makes it a lot easier to change the track type of several tracks at once.
                        There are also some bugfixes such as the Add Track tool now working in models with imperial units (stupid units using the same characters as are used as string delimiters -_- ).
                        I'm now also sponsored by a company called JPods to help them visualize their product for customers. JPods are small rail vehicles carrying just a few passengers each all the way to the chosen station within the network without any need for interchange. All powered with solar panels.
                        Download
                        Example Model
                        • deaneauD Offline
                          deaneau
                          @eneroth3 said:
                          Dean: My names are both Julia and Christina but most people say Christina. And I don't understand what that image has to do with anything.
                          this was picture language.
                          last theme was clearance/loading gaudge and the link i gave you was an inspiration.
                          if you compare all the measures american and european you will understand my picture.
                          in the US is all a littlebit bigger, then in europe. i dont know how good you know the american freight cars. there you have double-decker-container-cars like this.
                          http://www.railway-technical.com/cofc-double-stack.gif
                          and i have asking me, how look the tunnels there.
                          nice we
                          dean
                          • deaneauD Offline
                            deaneau
                            Home Page | The Railway Technical Website | PRC Rail Consulting Ltd
                            (www.railway-technical.com)
                            • deaneauD Offline
                              deaneau
                              about jPod is this a station or is this only a solar panele?
                              i cant see elevators or escalators
                              JPods - Wikipedia
                              (en.wikipedia.org)
                              looks nice.
                              this could be design in a game too
                              Google Search
                              (www.google.de)
                              will be different colors of cars a different line?
                              like this
                              do you know more about this system? ok elecrical (solar). in berlin we have had monorail
                              M-Bahn - Die Magnetbahn Referenzstrecke in Berlin - Nahverkehrstechnologie Entwickelt in Berlin - www.berliner-verkehrsseiten.de
                              (www.berliner-verkehrsseiten.de)
                              http://www.berliner-verkehrsseiten.de/m-bahn/M-Bahn-1988.jpg
                              • fionmacoolF Offline
                                fionmacool
                                Apologies if this has been already covered but I can't find a reference.
                                How do I change the train direction? Both when placing the train and when the train has been placed already?
                                Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                                • eneroth3E Offline
                                  eneroth3
                                  To go backwards you set the speed to zero and the reverse button gets enabled in the drive dialog. To place it the other way around I think you should press tab. I'm currently at my frinds house and don't have Sketchup or the plugin installed here but the status bar text in add rolling stock tool should say what key to press.
                                  [attachment=1:3s1hozl4]<!-- ia1 -->_2014.08.02_04h49m09s_024_00922.jpg<!-- ia1 -->[/attachment:3s1hozl4]
                                  JPods - Wikipedia
                                  (en.wikipedia.org)
                                  looks nice.
                                  Google Search
                                  (www.google.de)
                                  like this
                                  [attachment=0:3s1hozl4]<!-- ia0 -->_2014.08.02_05h19m08s_025_00923.jpg<!-- ia0 -->[/attachment:3s1hozl4]
                                  That's a solar panel. There wont be different lines. The pod goes all the way to the station you want it to go to.
                                  • deaneauD Offline
                                    deaneau
                                    thanks Christina,
                                    without Sketchup? wow. some times sketchup is a drug, and the sketchucation server was down here. some bad minutes or houres.
                                    http://de.wikipedia.org/wiki/Hl-Signalsystem
                                    and a little movie
                                    _2014.08.03_19h15m43s_002_00900.wmv
                                    trigger and contacts to switch sinals and brake shoe
                                    • eneroth3E Offline
                                      eneroth3
                                      Dean:
                                      Do you have the specifications this model is drawn after? I'd like to know the width of where the catenary can be and the default height. Measurements of the catenary support structure would be very useful too. Also if there's a specific color used on these that color code would be useful for drawing own catenary.
                                      • deaneauD Offline
                                        deaneau
                                        @eneroth3 said:
                                        Dean:
                                        do you talking about a german system, or what? we have in europe many different systems...
                                        when you can waiting a little time, i will search all about this. my information is based on german system.
                                        here a page about Swiss, Austria and Germany
                                        however geman language
                                        http://homepage.hispeed.ch/wili-the-wire/
                                        sorry, tecknical publications will be very rare and this special in english is more than rare.
                                        the table is spliited in Text, Drawing(blueprints) and photos. i think the Drawings will be important for you. dont wondering that some pictures in this page is before 1945,too.
                                        EDIT:
                                        dean
                                        • eneroth3E Offline
                                          eneroth3
                                          I haven't had time to check out the link until now. Some of the drawings seem really useful 😄 . I'm mostly interested in the German system but it seems to be quite similar the Swedish one.
                                          • deaneauD Offline
                                            deaneau
                                            i could look, to find some informations about differences. hight over rail head (SO in german). etc.
                                            ok is not your question however could look good in ERS
                                            https://www.htw-dresden.de/uploads/tx_templavoila/E-Highway.jpg
                                            dean
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
