    [Plugin] Eneroth Railroad System (v 0.1.21)
    364 Posts 43 Posters 176.2k Views 41 Watching
    • deaneauD
      deaneau
      @eneroth3
      ok
      @jonb42
      is simple:
      build your loco 1:1
      than
      draw a line 1435mm
      groop loco and line
      use the tape measure tool
      pick the first point of the line
      go to the second point and click
      enter your targed gauge in measurements (left below)
      this scale down the scene.
      if you only want scale down the loco and other object 1:1
      do this
      build your loco 1:1
      than
      draw a line 1435mm
      groop loco and line
      GROOP AGAIN
      go in the groop (double click)
      be happy
      if you need pictures or movie let me now
      regards dean
      • eneroth3E
        eneroth3
        @deaneau said:
        @eneroth3
        ok
        @jonb42
        is simple:
        build your loco 1:1
        than
        draw a line 1435mm
        groop loco and line
        do this
        build your loco 1:1
        than
        draw a line 1435mm
        groop loco and line
        GROOP AGAIN
        be happy
        regards dean
        This cannot be done on rolling stocks that are already initialized such as those in the rolling stock library. The scale would be reset when driving. Also it won't work on tracks. Scaling tracks with the scale tool changes the path they are drawn to and is used when you for instance want to change the radius or the length. The track is then redrawn with the same guage as before.
        My website: http://julia-christina-eneroth.se/
        • deaneauD
          deaneau
          ok this mean if the loco is build in 1:1 Scale and saved in the library scaling doesnt work
          if i design a H0 extrusion-profil (16,5mm) and build the loco in H0 scale and than save to the library this will work. right?
          hm, than have a model loco the same speed like a real loco. m/s. wow ๐Ÿ˜ฎ
          next
          what about a field to insert a radius.
          i have try to measure the radius for 10ยฐ and 20ยฐ curves. and when i calculate this with the rule of 3 i will have different results.
          is this a calculation error by sketchup or by the plugin?
          the real railroad in europe measure a curved track in Radius
          404 Not Found
          (www.dybas.de)
          the picture mean. the car can drive minimum this curve radius or higher.
          • eneroth3E
            eneroth3
            You can draw the locomotive at any size but then only use it at that size. Duplicating the same rolling stocks for different scales really isn't the right way to go. Also the slider in the drive dialog would be wrong unless the plugin doesn't know the scale and can adapt to it. The same goes for arrows in the switch tool and add rolling stock tool. I think it's easiest to draw in full scale in Sketchup. After all a model railroad is also a model representing the real world (or at least an imaginary part of it) which is in full scale.
            • deaneauD
              deaneau
              Hello i quick info about an exportplugin to a game...
              look here
              404 Not Found
              (sketchucation.com)
              • eneroth3E
                eneroth3
                Version 0.1.14 is out!
                There are a few new features. The biggest is probably that tracks has been split into the actual track and the structures to place along the track. this means that there are more combinations of tracks and structures but also that there can be several structures at the same place, e.g. a bridge and a platform alongside the track. Or a platform at each side.
                The old track types with structures built in are no longer shipped with the extension. You may want to remove these from the "Tracks/" subfolder in the plugin's folder before updating to get a cleaner track list. However that also prevents you from redrawing existing tracks of those types in the model unless you change the track type and add the structure separately.
                The signal system has also been updated and users can now create their own signals quite easily. There's also an option in Add Track tool and Track properties not to have any signals at all.
                Tracks with signals need to be fully redrawn to utilize the new signal system. This can be done manually by clicking them with the Track Position tool and go back (Esc or Enter) without changing their control points.
                Lastly the Track properties dialog now supports multiple tracks at once. This makes it a lot easier to change the track type of several tracks at once.
                There are also some bugfixes such as the Add Track tool now working in models with imperial units (stupid units using the same characters as are used as string delimiters -_- ).
                I'm now also sponsored by a company called JPods to help them visualize their product for customers. JPods are small rail vehicles carrying just a few passengers each all the way to the chosen station within the network without any need for interchange. All powered with solar panels.
                Download
                Example Model
                • deaneauD
                  deaneau
                  @eneroth3 said:
                  Dean: My names are both Julia and Christina but most people say Christina. And I don't understand what that image has to do with anything.
                  this was picture language.
                  last theme was clearance/loading gaudge and the link i gave you was an inspiration.
                  if you compare all the measures american and european you will understand my picture.
                  in the US is all a littlebit bigger, then in europe. i dont know how good you know the american freight cars. there you have double-decker-container-cars like this.
                  http://www.railway-technical.com/cofc-double-stack.gif
                  and i have asking me, how look the tunnels there.
                  nice we
                  dean
                  • deaneauD
                    deaneau
                    (www.railway-technical.com)
                    • deaneauD
                      deaneau
                      about jPod is this a station or is this only a solar panele?
                      i cant see elevators or escalators
                      http://en.wikipedia.org/wiki/JPods
                      looks nice.
                      this could be design in a game too
                      Google Search
                      (www.google.de)
                      will be different colors of cars a different line?
                      like this
                      do you know more about this system? ok elecrical (solar). in berlin we have had monorail
                      404 Not Found
                      (www.berliner-verkehrsseiten.de)
                      http://www.berliner-verkehrsseiten.de/m-bahn/M-Bahn-1988.jpg
                      • fionmacoolF
                        fionmacool
                        Apologies if this has been already covered but I can't find a reference.
                        How do I change the train direction? Both when placing the train and when the train has been placed already?
                        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                        • eneroth3E
                          eneroth3
                          To go backwards you set the speed to zero and the reverse button gets enabled in the drive dialog. To place it the other way around I think you should press tab. I'm currently at my frinds house and don't have Sketchup or the plugin installed here but the status bar text in add rolling stock tool should say what key to press.
                          [attachment=1:3s1hozl4]<!-- ia1 -->_2014.08.02_04h49m09s_024_00922.jpg<!-- ia1 -->[/attachment:3s1hozl4]
                          looks nice.
                          Google Search
                          (www.google.de)
                          like this
                          [attachment=0:3s1hozl4]<!-- ia0 -->_2014.08.02_05h19m08s_025_00923.jpg<!-- ia0 -->[/attachment:3s1hozl4]
                          404 Not Found
                          That's a solar panel. There wont be different lines. The pod goes all the way to the station you want it to go to.
                          • deaneauD
                            deaneau
                            thanks Christina,
                            without Sketchup? wow. some times sketchup is a drug, and the sketchucation server was down here. some bad minutes or houres.
                            http://de.wikipedia.org/wiki/Hl-Signalsystem
                            and a little movie
                            _2014.08.03_19h15m43s_002_00900.wmv
                            trigger and contacts to switch sinals and brake shoe
                            • eneroth3E
                              eneroth3
                              Dean:
                              Do you have the specifications this model is drawn after? I'd like to know the width of where the catenary can be and the default height. Measurements of the catenary support structure would be very useful too. Also if there's a specific color used on these that color code would be useful for drawing own catenary.
                              • deaneauD
                                deaneau
                                @eneroth3 said:
                                Dean:
                                do you talking about a german system, or what? we have in europe many different systems...
                                when you can waiting a little time, i will search all about this. my information is based on german system.
                                here a page about Swiss, Austria and Germany
                                however geman language
                                http://homepage.hispeed.ch/wili-the-wire/
                                sorry, tecknical publications will be very rare and this special in english is more than rare.
                                the table is spliited in Text, Drawing(blueprints) and photos. i think the Drawings will be important for you. dont wondering that some pictures in this page is before 1945,too.
                                EDIT:
                                dean
                                • eneroth3E
                                  eneroth3
                                  I haven't had time to check out the link until now. Some of the drawings seem really useful ๐Ÿ˜„ . I'm mostly interested in the German system but it seems to be quite similar the Swedish one.
                                  • deaneauD
                                    deaneau
                                    i could look, to find some informations about differences. hight over rail head (SO in german). etc.
                                    ok is not your question however could look good in ERS
                                    https://www.htw-dresden.de/uploads/tx_templavoila/E-Highway.jpg
                                    dean
                                    • eneroth3E
                                      eneroth3
                                      The typical height of the catenary would be useful to know. I know it's not constant in real life and can be lower under bridges for instance but since it would be constant in the plugin it would be useful to know what value to set it to.
                                      I don't have the time myself to draw lines for trucks but if I get the catenary to work any user could add it. I'll focus mostly on rail transport which is what the plugin is designed for and I've already proved it can be used for roads too even if that really should have its own plugin with features such as changing lane anywhere and driving manually.
                                      The main focus for the next release will be a new track drawing mode for continuous rail lines connecting points selected by the user. This will be much faster than the current method of adding short track segments and manually reposition them to desired length and angle. It will also support transition curves to reduce jerk when entering or leaving a curve.
                                      • deaneauD
                                        deaneau
                                        [attachment=2:28av6pjt]<!-- ia2 -->transition curve.png<!-- ia2 -->[/attachment:28av6pjt]
                                        [attachment=1:28av6pjt]<!-- ia1 -->main line.png<!-- ia1 -->[/attachment:28av6pjt]
                                        [attachment=0:28av6pjt]<!-- ia0 -->transition_example.png<!-- ia0 -->[/attachment:28av6pjt]
                                        hi Christina, yes thats right about different height.
                                        i the pictures you can see the red area, over the clearance diagram (blue /yellow) this is the room that can move the pantograph. in the short movie, you can see the movement of the wire along the pantograph (zig zag). when you will have the clearance diagram and the catenary i can send this via PM.
                                        MIBA have a german seria about railroad infrastructure (signals, catenary etc.)
                                        do you want remove complete the old system, laying out the tracks? this system was good for people will using your plugin for planing the modelrail road ๐Ÿ˜‰
                                        for example. if you want plan a mรคrklin board, this could build first in 1:1 and than, if i finished..you can scale this down to the H0,TT,N scale. ok than withot driving trains.
                                        https://shop.vgbahn.info/miba/shop/elektrische+fahrleitungen-_197.html
                                        https://shop.vgbahn.info/miba/shop/signale++band+1-_194.html
                                        MIBA have specialist literature not only for model railroader.
                                        however only in german ๐Ÿ˜‰
                                        actually i work on signals
                                        http://www.elektrische-bahnen.de/technik/ol_aufbau_1930.jpg
                                        dean
                                        • eneroth3E
                                          eneroth3
                                          The latest version with the new track drawing mode is now published. In Add Track Tool you can now click points in the model that will be connected with a continuous railroad line. Curves with customizable radius and curvature change rate will be automatically added at the corners. The old 'From Scratch' mode is of course kept but now called 'Junction' to distinguish it from the mode for drawing lines.
                                          From now on I'm also publishing the plugin without translations included since waiting for it to be translated has delayed the publishing process previously. Also I don't want to put pressure on the translators to finish their translations if they are busy or away from home. However I hope the translators will post their translations here once they've had the time to complete them ๐Ÿ˜„ . In the plugin's lang folder there's a file called template.txt that contains all strings to translate. By comparing this, eg. with the notepad++ compare plugin, to the old translation file you can see what strings has been added or removed.
                                          • deaneauD
                                            deaneau
                                            cool idea Christina, this will done more than fast.
                                            thank you ๐Ÿ‘
                                            dean
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 15 / 19
