    [Request/Idea] Component replacer in right click menu
    10 Posts 5 Posters 2.1k Views 5 Watching
    • N
      numerobis
      To replace a component with another you now have to open the component browser and search for the component in the list. Depending on the scene size this can be a very long list with hundreds or thousands of objects which takes several seconds to open even in list view and then you have to find your component...
      Now the request for a plugin: ๐Ÿ’š
      I think it could be useful to have a limited list of often used components in the right click menu with the ability to replace selected components or simply place a new one in the scene. The included components could either be build of maybe the last 10, 20 or 30 used components or predefined objetcs that stay in the list (or both).
      • R
        rv1974
        it already exists for years. get\apply definition of TIG(?)
        • N
          numerobis
          โ“
          ๐Ÿ˜ฎ where?
          • R
            rv1974
            ApplyTo 1.0 of Rick Wilson. Free on Smustard from 2004 A.C.
            Can't work without it.
            N.B. Digg Smustard, there are plenty of must have things.
            • G
              glro
              yes, the component window opening is slow when there are many many components to show
              you could create a special folder in the sketchup components folder, with the few components you need: it will open quicker
              • CadFatherC
                CadFather
                Thom's gem as well
                http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=26008%26amp;hilit=dropper
                  Rick Wilson's ApplyTo is one on my short list of absolutely must have plugins.
                  • N
                    numerobis
                    Great! Thank you very much! It works. I really missed this one... ๐Ÿ˜„
                    @cadfather said:
                    Thom's gem as well
                    http://sketchucation.com/click.php?url=http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=26008%26amp;hilit=dropper
                    It scales the new component to fit with the old one - this is not very useful in my case. But thanks! (i had it already installed ๐Ÿ˜‰ )
                    • CadFatherC
                      CadFather
                      look at the status bar: 'press CTRL'
                      • N
                        numerobis
                        thanks for the hint...!!! yes, it can be useful to look at the taskbar sometimes ๐Ÿ’š ๐Ÿ˜’
                        So it works too. ๐Ÿ˜„
