    Banca Desk
    19 Posts 8 Posters 2.8k Views 8 Watching
      A quick and easy model followed by a dead simple render in KT.
      Woke at 2:00 am this morning and couldn't sleep so I started perusing some of the furniture design sites in my Favorites list. I came across some interesting pieces by a fellow by the name of Torsten Sherwood. I'm not a fan of some of his pieces but I like this desk. The corners are joined with box joints which creates interesting details at the tops of the legs.
      On his website he has a link to a thing called the Sesame Seed Project. It's an "open design" thing with sort of plans for some pieces he's designed. Some of those pieces look rather flimsy and they are all rather rough, being made out of low grade pine and assembled with sheet rock screws but they might be useful as a starting point for designing your own furniture.
      FWIW, although it may not look it, the grain is running the in correct direction on this piece. The texture is from a photo of a lovely piece of maple with ribbon grain. I bet it was a big challenge to plane it smooth.
      • D
        davidheim1
        Cool.
        The guy has nerve, cutting very long tongues for the box joints from pine. The table also seems to have one piece of interesting engineering: It looks as if he splits the pieces for the legs, then spreads those thin pieces to wrap around the box joint.
        Thanks for this.
        dh
          Hi David,
          They are quite long for box joints, that's true. I don't think he split the legs, though. If you look at his website he has a photo of the top of one of the legs. It looks like the leg is made from four bent pieces. That's how I drew it, too although you can't tell in my render.
          I made a guess at the thickness of the legs and made each piece 5/8-in. square. The aprons are 5/8-in. thick and the fingers of the box joint are 5/8-in. wide. that makes the fingers 1-1/4 in. long.
          • boofredlayB
            boofredlay
            Stunning Dave.
              10Q
              • pbacotP
                Great model. Nice legs...Haha
                Really, good job on the table and render. I haven't thought of Sketchup when I can't sleep. I "build" enough stuff in my head at night as it is.
                  Thanks Peter.
                  If I didn't have to worry about waking up the family I'd be out in the shop building real stuff. At least SketchUp is quiet. 😉
                  • M
                    mwm5053
                    Nice job Dave, 👍 Very interesting piece
                    2011 iMac
                    SU 2015 Pro, 2017 Make
                    V2 Twilight
                    macOS Sierra 10.12.5
                    • D
                      davidheim1
                      Dave,
                      More on those legs. If the legs are four pieces glued and bent, the glue joint will be in tension. Wonder how long it takes for one of those joints to fail? If the leg is split, then the joint where the legs intersect the box jointed stretchers is in compression, so it might be stronger in the long term.
                      None of this has anything to do with SketchUp, of course. I'm just curious. Yours is a nice model and a nice render.
                      Best,
                      dh
                        Thank you, Walt.
                        Thank you, David. I was thinking about those legs and figuring that my approach would be to steam them to put the bends in and reduce some of those stresses. I'm guessing Mr. Sherwood didn't do that, though. I think the hardest part would be to get four legs that are all the same.
                        • M
                          mwm5053
                          I agree with David about the glue joints at the top of the legs (not good just a butt joint). I like some of
                          his (Torsten Sherwood) designs but I think he needs a course in wood working.
                          I would use one piece of wood or 4 pieces glued together if you wanted to maintain grain direction.
                          Then use a mortise machine for the mortises and also for the tapered mortise down to where they started to taper then either chisel the rest or scroll saw then a chisel. Then for the outside taper a bandsaw. And sand to finish. I'll bet Norm and David Marks might do different though. I wonder what some would say at Fine Wood Working?
                          2011 iMac
                          V2 Twilight
                            Walt, there's no butt joints in the table and no mortises in the legs for that matter. The aprons are joined together with a box joint and the four piece of the leg are glued into the corners. Lots of face grain glue surfaces so that part would be quite strong.
                            I agree most of the furniture looks like it could do with some refinement. On the other hand his target audience seems to be those apartment dwellers with little to spend on furniture, litte in the way of tools and who would build it themselves. I think it's more of that 'maker' philosophy like open Desk but without the need for expensive CNC machines or really any power tools at all.
                            • D
                              davidheim1
                              Dave has a point. Steaming the components of the legs would reduce the stresses where the four pieces join, as well as around the box joints.
                              dh
                                @davidheim1 said:
                                Dave has a point.
                                I do tend to wear a hat, though, so it isn't very obvious.
                                • M
                                  mwm5053
                                  Dave oh I see now 😳
                                  2011 iMac
                                  V2 Twilight
                                  • G
                                    Gene Davis
                                    My first take on it was a mistake. I made all the components 3/4" thick, not 5/8".
                                    I think I'll go back at it and do it all in 16mm parts thickness.
                                    With white pine, I don't think there is much to be gained by taking all the trouble to bend with steam. Today's glues should hold all together just fine. There is a lot of long grain to long grain in the joinery.
                                    The top is a floater. The project should make for a pleasant weekend in the shop.
                                    • G
                                      Gene Davis
                                      And here is a thought about those legs and whether to pre-bend.
                                      Consider it done with a little design change, that of adding a collar of carbon-fiber tape to the legs right where the curve ends above the bottom straight segment. I'll have to see whether carbon fiber can make the 90 bend without compromising its strength. The visual can be called an enhancement.
                                      Another option for the wrap-tie would be a 19mm length of square brass tubing. Available in 1.25" square at .100" wall thickness, it would fit snugly to the legs if the quarters were milled to precisely 16.5mm square, or right under 0.650". See this site for the brass. http://www.lewisbrass.com/tubing/square-brass-tubing-3/
                                      A pic of one leg, wrapped thus, is shown here.
                                      • jeff hammondJ
                                        jeff hammond
                                        nice texturing Dave 👍 (as in- real nice)
                                        a glass top alternate idea for that joint-- the middle one is lower than the other 3 and provides a pad for the glass.. the other 3 keep the glass in place.
                                        dotdotdot
                                        • J
                                          jtri
                                          There is an easy way to make the legs if you the time to sort through some lumber. As this is a gentle curve, if you can find a board that has this curve in the grain and then cut it out on the band saw it should be very strong. I was taught this by an Englishman that said the shop he apprenticed in always sorted out lumber with the grain curved to use for curved legs. They especially like boards cut near the buttress of the tree as they were always curved and had lots of uses. Nice table Dave.
