    Problem map texture, error position texture.
    1 Posts 1 Posters 1.4k Views 1 Watching
    • C
      comixo
      hi sorry about my bad englis
      i have a big problem whit SU, when i mapping the texture, the texture go wrong, i will try to explain, when i click on texture, and click to texture edit, and take the ping green, to make bigger the texture, appaer 2 texture, the same texture, but a litle move, then when a finish the screen map (not the map editing) its wrong, because when i export to fbx, the right map its the edit mapping, but this its moved, let me show whit a video.
      in the video u can see, the map its moved, in sketchup screen normal, but when i edit the map position the texture show me 2, of the same texture, and the rigth texture its the moved texture, the texture when i editing position.
      and teh model part.
      https://www.dropbox.com/s/7ylvozp191en4xl/lateral.skp
