    Podium V2plus and Vray together ?
    extensions
    2 Posts 2 Posters 660 Views 2 Watching
    • M
      Matheos
      I've got Sketchup 2014 with Podium V2plus running. But because I am curious about Vray I do want to install the Vray demo, but I'm not sure both plugins will bite each other. Does anyone know if this is possible?
      • D
        driven
        yes. it is possible they will bite each other...
        but if you turn them both off, using the SCF plugin, then turn them on ONE at a time you should be OK to test...
        john
