    Podium V2plus and Vray together ?
    extensions
    2 Posts 2 Posters 633 Views 2 Watching
      Matheos
      I've got Sketchup 2014 with Podium V2plus running. But because I am curious about Vray I do want to install the Vray demo, but I'm not sure both plugins will bite each other. Does anyone know if this is possible?
        driven
        yes. it is possible they will bite each other...
        but if you turn them both off, using the SCF plugin, then turn them on ONE at a time you should be OK to test...
