    Vray beginner needs help
    renderpluginsextensions
    3 Posts 3 Posters 481 Views 3 Watching
      awesomewang
      Hi guys,
      Just start to try rendering with vray for days. And im struggling with this basic problem for days. The output pic size. I set the output size into 20481536 in the with "override viewport checked". than press render. It still comes out with the 533400 pic.
      plz help
      • N Offline
        njay
        Beginner myself, but I had same issue and solved it by checking and then unchecking the override viewport box a couple of times.
        Not consistent, but did eventually work.
        Hope that helps
          rspierenburg
          You can definitely try what njay suggested, but it would help the community to know what version of Vray you are using as there have been bugs in earlier editions that have since been fixed.
