    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    SUbD - Non-destructive subdivision with creases and quads
    79 Posts 25 Posters 15.0k Views 25 Watching
      Play piano during a sketchup session is a real task! ๐Ÿ’š
      Seems you master the 2 actions with brio! โ˜€
      Well, you know - I have so much spare time to kill that I figured - "why not?". ๐Ÿ˜‰
      Does all this Ruby 2 ?
      I've only been developing in SU2014 Windows. Other platforms and SketchUp versions will be tested once I reach the stage of beta testing.
      At the moment I'm not sure if it will require SketchUp 2014 or not.
        @panixia said:
        @thomthom said:
        Last on the todo list.
        ๐Ÿ˜ข
        Hey, if you insist on throwing money at me before it's done - by all means! ๐Ÿ˜„
        @panixia said:
        @thomthom said:
        The one in the QuadFace Tools toolbar?
        yes.. that one.. ๐Ÿ˜Ž
        It's a tool to draw non-planar quads. It's still in beta stage, but works ok.
        • panixiaP Offline
          panixia
          ๐Ÿ˜† I would have bought it since day -1.. as far as i can see is just as perfect as it is to buy..
          • pbacotP Offline
            Keep coming back to this thread, but each time there's only more drool on the floor.
            • andybotA Offline
              andybot
              any chance "loop cut and slide" is possible? There's add loop in Quadface Tools, but specifying where within the quad the loop goes would be HUGE! Anyhow, just dreaming ๐Ÿ˜„
                Can you elaborate more? "slide"?
                You mean like a insert loop by offset from reference edge?
                • andybotA Offline
                  andybot
                  It's a Blender command. It allows you to place a loop by percentage distance between adjacent loops. Offset by distance from edge would be nice too ๐Ÿ˜„
                    jaceguay
                    Yes, it would be very usefull.
                    • StinkieS Offline
                      Stinkie
                      Oh, wow!
                        cuttingedge
                        ๐Ÿ˜„ the hope for a cleaner model in SU acceptable to the high standard cg world.
                        • panixiaP Offline
                          panixia
                          the workaround i use in order to mimic this is to select the ring then use "connect edge" with 2 segments and the proper pinch, then "remove" the unwanted loop
                            Yea, that's awkward - need a better function.
                            • panixiaP Offline
                              panixia
                              maybe. but we love you anyway. just don't worry about this and focus on sub-d ๐Ÿ’š
                              can't wait ๐ŸŽ‰
                                Long time, no post. I just updated the topic with a new video ๐Ÿ˜„
                                Live crease adjustment on the limit mesh
                                  Cool! ๐Ÿค“
                                  • StinkieS Offline
                                    Stinkie
                                    Indeed. ๐Ÿ‘
                                      Teasing! ๐Ÿ˜„
                                        Teasing! ๐Ÿ˜„
                                        ๐Ÿ‘ฟ
                                          ๐Ÿ˜„
                                          Take your time: it's holliday soon! โ˜€
                                          • panixiaP Offline
                                            panixia
                                            ๐Ÿ˜ฎ
                                            • 2 / 4
