    Is there a <select equivalent for <input onClick?
    7 Posts 5 Posters 887 Views 5 Watching
    • sdmitchS Offline
      sdmitch
      "<input ... onClick=" sends info to a designated call back routine. Is there an equivalent that can be used in a <select that would trigger when the selection changes.
      http://sdmitch.blogspot.com/
        Like SelectionObserver ?
          Jim
          I think he means an html select element.
          http://msdn.microsoft.com/en-us/library/ie/ms536967%28v=vs.85%29.aspx
          http://stackoverflow.com/questions/647282/is-there-an-onselect-event-or-equivalent-for-html-select
          • jiminy-billy-bobJ Offline
            jiminy-billy-bob
            http://api.jquery.com/change/ ?
            • sdmitchS Offline
              sdmitch
              Yes, exactly. Now if I can just figure out how to "Trigger the handler".
              If anyone has any ideas on how to make this work in Sketchup, please pass them along.
              • Dan RathbunD Offline
                Dan Rathbun
                The better page for more info on the Select element is here:
                http://msdn.microsoft.com/en-us/library/ms535893(v=vs.85).aspx
                There are several ways to fire the onselect event:
                Assume that "droplist" is the id for your select element.
                %(#8000BF)[dlist = document.getElementById("droplist");]
                Set the selected index to the third option, on the select element:
                %(#8000BF)[dlist.selectedIndex=2;]
                Call the %(#8000BF)[click()] method on a specific option element by it's id:
                %(#8000BF)[opt_green = document.getElementById("option_green"); opt_green.click();]
                Call the %(#8000BF)[click()] method on a option element by it's index:
                %(#8000BF)[opts = dlist.childNodes(); if opts.length > 0 { opts[2].click(); } else { \\ handle empty array }]
                PC also has the %(#8000BF)[fireEvent()] method, but you probably should stay away from platform dependant methods.
                πŸ’­
                I'm not here much anymore.
                • sdmitchS Offline
                  sdmitch
                  Thanks much Dan for the info. Looking back at by previous posts, I see that I never made it clear that the question is relative to a WebDialog associated with a plugin. Don't know if that matters but just so you know.
                  Eureka I have found it. It was all a matter of where the onChange was. Because the onClick was part of each radio button statement, I assumed it was the same with the select list. Instead it just needed to be in the <select> statement itself. Thanks again to one and all for the links that put me on the right path to find the answer.
                  def showme()
                    @dlg=UI;;WebDialog.new("VerySimple", true,"Test",500,300,10,10,true)
                    @dlg.set_html(
                      "<html>
                        <body>
                          <form>
                            <select onChange='tellSketchup(value)'>
                              <option value='option1' >Option 1</option>
                              <option value='option2' >Option 2</option>
                            </select> ; Head Type<br><br>
                          </form>
                          <script type='text/javascript'>
                            function tellSketchup(value)
                                window.location='skp;OptionChanged@'+value;
                          </script>
                        </body>
                      </html>"
                    @dlg.show {} #show it
                    @dlg.add_action_callback("OptionChanged") {|d,p|
                      puts "OptionChanged value=#{p}"
