    Plugin Friendly SketchUp 2014
    9 Posts 5 Posters 783 Views 5 Watching
    • john2J Offline
      john2
      Instead of we sketchup users bugging plugin makers to upgrade their plugins for v2014, is there a possibility that the guys at Google SketchUp edit the software architecture of sketchup so that older plugins are still compatible and SU 2014 users can easily work in it?
        So you're suggesting that SketchUp go back to using an older version of Ruby? That defeats the benefits of using the newer version of Ruby. If you want to stick with the old Ruby then go back to using an older version of SketchUp.
        By the way, it hasn't been "Google" SketchUp for some years.
        • john2J Offline
          john2
          Oops that's embarrassing. Sorry, Trimble Sketchup. 😳 And is there a fast way to convert old ruby script to a new one?
            I expect it depends upon the plugin. If plugin authors are still active and aware of it, they'll be updating their plugins. Most plugins have been updated as it is. What is the big problem with contacting the authors for those few plugins that haven't been updated already? You could just learn Ruby and do it yourself, I suppose.
            • john2J Offline
              john2
              Im having trouble with compo spray and Didier isnt updating it.
              Sent from my Micromax A110Q using Tapatalk
              • cottyC Offline
                cotty
                Maybe you can try to find a workaround with some other plugins? e.g.
                • Make Fur
                • Raytracer
                • Throw To
                • Components onto faces
                my SketchUp gallery
                • tt_suT Offline
                  tt_su
                  I'm afraid there is no way we can make SU2014 be 100% compatible with the previous versions. We really want to keep backwards compatibility as much as possible but this time we had to take our medicine and update Ruby.
                  Ruby 1.8 has reached end of life and is no longer maintained. It also imposed several limitations and issues, particular related to Unicode for handling international characters and security permissions. Since Ruby is a third party product we are somewhat bound by their development.
                  In this case it was a damned if we do, damned if we don't - and weighing in all pro's and cons the pros for upgrading outweighted the cons. It was the only way we could ensure we have a platform for plugins that we could maintain properly.
                    I expect Didier is busy with other things that are higher priority. Maybe if you offered to pay him for his effort he would be able to make some time for it.
                    • aarondietzenA Offline
                      aarondietzen
                      Alas... that is the life of a plugin developer... You have to roll with the changes of the host program. I will say, though that SketchUp did an excellent job of alerting us to the upcoming changes and gave developers plenty of time to make changes before 2014 was released. Not all software companies give their API users that much time to get compliant before releases!
                      "Imagination is more important than knowledge..."
                      - Albert Einstein
