    Problem Importing .obj File into SU Make 2014
    2 Posts 2 Posters 1.1k Views 2 Watching
    • BSquared18B Offline
      BSquared18
      While working on a flight-simulation aircraft project in X-Plane, I wanted to import into SketchUp Make 2014 an X-Plane object created by using the Special --> Generate OBJ from aircraft feature in Plane Maker 10. The SketchUp plugin SU2XP (for interfacing with X-Plane) has been installed.
      After creating the object, I opened SketchUp and went to File --> Import --> X-Plane Object. Instead of importing the object, SketchUp had the message that it couldn't do it because of an internal error.
      During a Google search, I saw a number of programs for converting a .skp file to an .obj file, but none doing the opposite. The SU2XP plugin works great for making the .skp to .obj conversion, but I'm trying to go the other way.
      A while back I was able to successfully import an aircraft object, but not now.
      Any suggestions?
      Thanks,
      Bill
      • V Offline
        valerostudio
        TIG has a great OBJ importer.
        http://sketchucation.com/plugin/733-obj_importer
