    A better "Solids" representation.
    1 Posts 1 Posters 1.7k Views 1 Watching
    • jgbJ
      jgb
      This is actually a 2 part (related) suggestion.
      1. Right now if an object is a solid, its volume is shown in Entity Info.
        Then I have to define outside of SU its material density and compute its weight.
        Then I have to go back to components and in the description, enter the weight in a unit of choice.
      The problem here, aside from the extra computations, is that if I change the units, the weight is not in the changed units (ie: kg/lbs), or if I modify the solid object, the defined weight must be recalculated and re-entered.
      The solution is to define in SU Materials, a density for any material that would apply to a solid, ie: concrete, aluminum, steel, etc. Then let Entity Info display the weight in any current units.
      Allow for manually entering/editing any materials density. Just colors would be zero density.
      So how would SU "know" an object is a defined density material, considering you can paint an object in multiple colors/materials?
      Simple. πŸ’­ Allow the exterior faces of the object to be any color or material, but the INTERIOR FACES MUST be 100% a single defined density material. πŸ’­ (99% and no weight calc.)
      1. When an object is displayed with a cut through section plane, a solid objects interior is quite visible making it difficult to visualize as a solid, especially if a section cut is printed/exported for others to see. This visualization is particularly difficult if the section cut is through a complex mechanical assembly like an auto transmission. You cannot discern the gears and bits.
      πŸ’­ Using the criteria from above to identify a solids material (interior faces), the section cut of only the solids should be faced with the solids material. πŸ’­ This cut face is only seen in section cuts and are not part of the objects geometry.
      jgb
