    Crystal curtain ideas
    3 Posts 3 Posters 263 Views 3 Watching
      JLenhart
      Hello,
      My name is Jason. I have been attempting to create a crystal curtain but ran into some issues.
      I got the basic crystal build but I have run into an issue the curtains I am trying to build is 3'x 1" x 12' so I have about33 strands of 230 crystals each, So once I get more then 3 strands it really starts to stress the program. so my question is has anyone found any way/ have any ideas on how to keep crystals looking realistic without adding a huge load to sketchup?
      I have been using 2D image until recently where I want to make them "shimmer"(more so just have them simi transparent and allow my render add on to bounce some light around/ look more realistic.
      My current thought is to drop the crystals them self down to 3-5 sides to reduce the amount of faces but I will lose a lot of detail doing that.
      • mitcorbM Offline
        mitcorb
        Hi:
        I presume you are using Components and copies of these to populate your file? If so, are the strands hi poly? These could be simply 4 facets.
        There may be other conditions, but this is what came to my mind.
        • soloS Offline
          solo
          Depending on your render software you could use a proxy instead.
          http://www.solos-art.com
