    Move objects to surface command or plugin?
    2 Posts 2 Posters 335 Views 2 Watching
    • dshafferD
      dshaffer
      Hello -
      I would like to be able to draw multiple objects on a horizontal plane then drop them down to a contoured surface. For example, I'd like to make a fence picket component, repeat it hundreds of times on a horizontal plane, select them all, then use a command or plug-in to drop them down to a contoured terrain.
      I tried the "Smartdrop" plugin, and it drops the objects to the terrain, but it also rotates the objects so they are perpendicular to the terrain.
      I found a tool on Smustard called DropGC that sounds like it would do the trick, but I'd rather use a tool from Sketchucation so I can update and track it using the Plugin Store / Manager.
      Thanks -
      Doug
      Doug Shaffer
      McHenry Shaffer Architecture
      Sketchup Pro 2021, Vectorworks 2021, Mac
      • cottyC
        cotty
        Search for throwto plugin
        my SketchUp gallery
