    A Simple Copy Plugin Needed
    3 Posts 3 Posters 303 Views 3 Watching
    • C
      Cubcrafter
      I am looking for a simple plugin that will allow me to copy components or groups. I want to activate the copy command and then I want to select an object's corner and then simply click a point on the screen to place it. I want the object to stay attached to the cursor so I can place it again and again without selecting the move tool and control key.
      I need to select various components that have already been placed in the drawing. I don't want to go to the component window to find the right component again and again.
      I don't want to keep hitting the shortcut keys to copy things in my project.
      I am not looking to make an array of objects, just simply placing many copies of the same component where I want them by drawing over an imported dwg file.
      This is something that I can do with my 2d program (Microstation) and I hope SketchUp can do as well.
      I am looking at this as something that will speed up the framing plans that I am doing. I then run the CutList plugin to get a material takeoff.
      Hopefully I am not asking for too much, this seems on the surface to be a simple copy command. I have tried the Component Placer plugin but it is far more complicated than what I need and really does not do what I want.
      Larry
      Framing Model
      Framing Model
      • jeff hammondJ
        jeff hammond
        Chris Fullmer has a repeat copy plugin available for $10
        http://extensions.sketchup.com/en/content/clf-repeat-copy
        dotdotdot
        • dukejazzD
          dukejazz
          move tool
          with control key held down
          will copy and paste over and over
