    Importing STL into Sketchup
    4 Posts 3 Posters 812 Views 3 Watching
    • ANBenderA
      ANBender
      Hello Friends at Sketchucation,
      I am trying to import STL files into Sketchup but Sketchup's plugin that is supposed to provide both exporting and importing STL files only has a export STL option. Any suggestions? Thanks in advance. β˜€
      Amos Bender
      • K
        kaas
        Amos Bender
        did you try file-import-(change extension to *.stl) and pick the stl file ? If you use Sketchup's stl plugin this option should be there.
        • J
          Jim
          To import .stl files, go to the "File > Import..." menu, then select the "STereo Lithography .stl" in the file type drop-down.
          Ideally, the Exporter would be under "File > Export > 3D Model..." but SketchUp does not support adding exporters there yet.
          • ANBenderA
            ANBender
            Jim,
            Thanks so much that worked! I just did not know "STereo Lithography was STL and did not look close enough.
