    2d graphic export only edge
    6 Posts 4 Posters 1.3k Views 4 Watching
      mt9ops
      I have this problem. When I export in 2D graphic only the edge appear in the image. When I look on my model in Sketchup, I see my model with the edge and the face. I try on a different computer with the same model and it work. I don’t always have access to a different computer so I need to fix it. I believe it an export option that is activate that say export only the edge. I don’t where to find the export option. I link an image of my export result.
      Thank you for your help
      Max
        Seems not! (in V8)
        The export options of the 2D export are only size and anti aliasing!
        Or also compression when you choose JPG
        Seems you have enable Xray mode ?
          This has come up several times before. It is generally an issue related to the GPU. Try changing OpenGL and Hardware Acceleration settings under Preferences>OpenGL. Also check for updated drivers for your GPU.
            mt9ops
            Thanks it work!
              What exactly worked?
              Someone else with the same problem might actually read this post and find that what you did will help them.
                danjrosen
                I had the same problem exporting 2d image only exported edges.
                This worked for me Thanks!
