    Strange Section Cut Profile Behavior
    12 Posts 5 Posters 678 Views 5 Watching
      matt.gordon320
      Hi Guys,
      I'm having an issue with section cuts producing oddly dashed (yeah, dashed) lines both in viewport and exports working with a particular landscape, and I can't figure out why. I'll let the model upload to dropbox or the like, but here's an image in the mean time.
      EDIT: I'm using 2013, and the active style is a slightly modified version of the default Arch template, with everything but lines turned off, and white/red front/rear faces respectively.
      Any thoughts?
      -Matt
      • cottyC Offline
        cotty
        Have you tried with a different style?
        my SketchUp gallery
          matt.gordon320
          Yes, unfortunately no difference 😞
            It looks to me as if you're using a line style that has a Halo setting and perhaps a relatively low Level of Detail setting.
            • BoxB Offline
              You might what to check if it is related to this section cut shadow bug.
              http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57115
                matt.gordon320
                The Halo setting is only available in Sketchy Styles isn't it? I'm using a modified version of the default style with essentially everything but lines turned off.
                Also, using v2013. Still stumped.
                  Yes. You're right. I couldn't tell what your style settings are from just the image you posted.
                    matt.gordon320
                    Sorry Dave, I didn't exactly post as much info as I should have 😳 I'll go back and edit.
                      No worries.
                      What happens if you change the Section Cut edge weight? Does orbiting change the view at all?
                        matt.gordon320
                        @dave r said:
                        No worries.
                        Orbiting has no effect, and oddly enough, changing the line weight only changes the dashes lineweight, ie the missing bits are still missing.
                          Weird.
                            driven
                            does it change with show/hide hidden detail?
