    Vray 2.00.24261 Vray RT error?
    renderpluginsextensions
    8 Posts 4 Posters 5.6k Views 4 Watching
    • Z Offline
      Zylescozar19
      Hi! I installed Vray 2.00.24261 when i try to activate vray-RT it doesn't work.
      can anyone help me with this issue?
      Thanks.
      • dkendigD Offline
        dkendig
        any errors?
        Devin Kendig
        Developer
        • Z Offline
          Zylescozar19
          See attached.
          • dkendigD Offline
            dkendig
            are you able to a regular render?
            Devin Kendig
            Developer
            • Z Offline
              Zylescozar19
              yes. my only problem is the vray-RT.
              • dkendigD Offline
                dkendig
                You need to be sure to have XMLDRSpawner running (it should be started when you load our plugin, but some people like to close it for some reason), and if you have DR enabled, you need to be sure that all referenced spawners are running the same version as what you have installed to SketchUp. Also, are you doing a CPU or GPU RT render?
                Devin Kendig
                Developer
                • I Offline
                  ismailyameen
                  hey i m also experiencing the same problem while rendering using RT render in vray ,sketchup crashes
                    RockCity_Bishop
                    I am also have this problem. How do I check the XMLDRSpawner running?
