    Old Mirror plugin won't work in 2014. Options?
    6 Posts 4 Posters 559 Views 4 Watching
    • C
      CalypsoArt
      I have the mirror plugin that had the later versions managed by TIG. However, it will not work in SU 2014. Is there some minor text code tweak I can make to have it be compatible? Or is there another mirror tool out there as simple? I use this constantly. I can't live without it.
        Mirror works fine in 2014 so I say the version you are using is old
        • BoxB
          Tig's mirror works perfectly in 2014.
          If you looked at the link I gave you yesterday you would have been able to download and install the Sketchucation plugin manager, through which you could install Mirror along with 600 or so other plugins.
          Mirror toolbar and mirrored component in SU2014
          • C
            CalypsoArt
            Thank you. I missed your link. I just thought it was one of the AdMachine posts/adds that show up in threads. I had the Sketchucation plugin manager in 2013. I was trying to load the pluggins I use the most first. Mirror is #1. I should have loaded Sketchucation first.
            thanks again.
            • cottyC
              cotty
              I know what you mean, Box is answering questions as fast as a robot... 😎
              my SketchUp gallery
              • BoxB
                If you are getting ad links within the text of people's posts they aren't from this site, they are an adbot that has got into your system.
