    Using LO to display SU BIM info
    layout
    4 Posts 3 Posters 811 Views 3 Watching
    • A
      austinar
      Hi everyone,
      Just curious, I haven't done/found much on this subject...
      The project I'm working on is for calculation the Net Internal Area of a series of flats, I'm having to produce a NTS plan and a list of room areas, along with a total area
      Q. Is there a way to use SU's new BIM parameters to output a list of areas into LO or seperately?
      (I'm currently having to calculate & add each room individually... And would like to automate the process)
      Regards
      Austin
      • C
        caronte01
        Hi Austin.
        Not exactly in layout, but in sketchup, have you tried fredo's report areas plugin"? It does what you need, based on material area. It will export to xls, or even label each face based on it's area. Search for fredo6 tools. Report on area and report on label area.
        Santiago
        • KrisidiousK
          Krisidious
          Also, although I have it installed I have not used LSS Zone
          https://extensions.sketchup.com/en/content/lss-zone
          By: Kristoff Rand
          • A
            austinar
            Ahh thanks guys, out on site atm but I'll check both of those out when I'm back!
            The main thing is I want to get the process time down
