    Line Transparency Issue
    5 Posts 3 Posters 428 Views 3 Watching
    • W
      whiskeytangofoxtrot
      Hello,
      Im having an issue with lines showing up through objects that are supposed to be opaque. I am modeling a sheet metal skin that overlays a wooden structure, and the wooden ribs show through the 0.06" thick metal.
      The materials dialog claims that the material is solid. The problem persists despite
      -changing colors
      -scaling up the model so that the metal is 6" thick
      -using a variety of different style settings
      -turning off and on various OpenGL settings
      Really hoping for some help here. Im down to the wire on a freelance project and cant seem to figure this out.
      Side view of the metal skin and ribs
      The problem - rib lines showing through the sheet metal
      • BoxB
        Have a read here.
        http://sketchucation.com/resources/tutorials/37-beginner/315-edges-bleeding-through-geometry
        • W
          whiskeytangofoxtrot
          The only way I can get the rib lines to stop showing up is to turn off both Edges and Profiles - problem persists when either is clicked, even alone.
          I made the skin 0.125 thick, problem persists...
          • W
            whiskeytangofoxtrot
            Thanks, Box.
            That really cleared things up. Ahem.
            When I export at hi res, the problem disappears. Im testing at my animation resolution, and that looks fine so far too.
            -Wtf
            • arail1A
              arail1
              @box said:
              Have a read here.
              Thanks for that. It's a problem I run into continually relative to a particular product I have to draw in many variations (drum shades for a retail client) so a workaround is very much appreciated.
              If it's any consolation the problem is more apparent in Rhino than in SketchUp. Not sure why.
