    SU to AI
    5 Posts 2 Posters 574 Views 2 Watching
      Rudbeckia
      Does anyone have an idea why when I export a model scene as a pdf then open in illustrator, the lines come in with one line being many. Meaning it like there are lines stacked on one another
      Is export 2d graphic as PDF the best way to go from skecthup to illustrator?
      • charly2008C Offline
        charly2008
        the export as PDF provides the best qualitative result. see Example
          Rudbeckia
          the export to pdf is bringing the contours into AI as not lines. the contour lines are thousands of segments
            charly2008
            Can you explain what you want to do in AI?
              Rudbeckia
              I want to embed the pdf so I can work with the lines in AI
