    Error in the view (Vray 2.0)
    renderpluginsextensions
    2 Posts 1 Posters 441 Views 1 Watching
    • D
      dacastror
      (google translator) Hi, I wanted to make some renders from certain perspectives perfectly aligned with the geometry. I created a scene for rendering always from the same place and I notice that sometimes fails Vray, for some strange reason, Vray rotate the view slightly (roll) sometimes, as show below:
      Defective render
      Proper render
      apparently this error appears especially if you render several times from the same view, I use "Sketchup 8" and "Vray 2.00.23490"
      I attached the skp corresponding to images, although this error appears on any skp
      view.skp
      I do not know if this has any solution
      • D
        dacastror
        apparently this problem has been fixed in version 2.00.24
