    [Plugin] Add comments to your file
    104 Posts 20 Posters 22.0k Views 20 Watching
    • JClementsJ Offline
      JClements
      Hi I,
      Check your personal messages for link info.
      link to specific image
      link to entire album
      • chialiang168C Offline
        chialiang168
        Comments-icon_v2.3.5 Test report
        An error occurred in IE10
        https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/Comments(文字註釋)v2.3.5/圖片/Error.gif
        Increase Chinese language file
        Increase China-Taiwan language files
        Dropbox - 404
        (dl.dropboxusercontent.com)
        • inteloideI Offline
          inteloide
          Hello,
          thank you for translation : I added it to the plugin.
          Please try attached version which should solve your issue, and let me know in order to officially post this version.
          Improvements are :
          2.3.7 Corrected : Avoid menu error
          Optimized : Added chinese languages (thanks to chialiang168)
          2.3.6:	Updated : 	version of ckeditor update to 4.4.5
          		Added :		Change tab key behavior to add spaces (4)
          		Corrected : enter key now make a simple return to line
          Regards.
          Inteloide
          Version 2.3.7
          Humanity will do a huge step when the IT professionals will understand that computers are tools...
            chialiang168
            https://dl.dropboxusercontent.com/u/108539326/001-Share/022.gif
              inteloide
              Lovely!
                BMoffa
                I would really like to use this plug-in, but it seems to not save or not load comments that I add. At first it lost comments from one of the two tabs I set up, then it lost everything.
                I'm using version 2.3.5 in SketchUp 2015 Pro 64 bit (current build). I really hope you can fix this as I really like it.
                  inteloide
                  Hello,
                  Please download version 2.3.7 from the store or from the first post of this thread, and please tell me if solved your issue.
                  Best regards.
                  Inteloide
                    Lê Việt Trường
                    Thank you for this usefull plugin!
                      Lê Việt Trường
                      Hi there,
                      Thanks for the ruby, but where it saves the comments? I lost some tab's comments and can not get it back
                        inteloide
                        Hello Lê,
                        Please download the latest update of BGSketchup Library from the store (version 2.3.1).
                        It may solve your issue.
                        To answer your question, comments are saved inside Model (let's say Inside skp file).
                        If you loose some comment, you can send me your file (even if you delete everyhting inside) and I will try to recover it.
                        Inteloide
                          bharralure
                          Bonjour Inteloide,
                          J’utilise depuis quelques semaines votre plugin "Comments v2.3.7".
                          Il fonctionne correctement sauf qu’à chaque lancement d’un modèle SketchUp comportant des commentaires enregistrés s’affiches les messages tels que les montres les captures d’écrans ci-après :
                          Est-il possible de solutionner ce problème ?
                          Merci.
                            bharralure
                            Bonjour Inteloide,
                            Je viens de solutionner mon problème en installant la version 2.3.2 de BG_Sketchup_Library (j'utilisais la version 2.0.7 sans avoir vu la mise à jour...).
                            Tout fonctionne.
                              inteloide
                              Bonjour,
                              Il vous faut télécharger la dernière version de BGSketchup_Library (la version 2.3.2).
                              Pour cela, vous pouvez allez, dans Sketchup, dans le menu Extension puis BGSketchup puis BGSketchup update manager.
                              Là vous tomberez sur l'interface qui vous permettra de mettre à jour vos plugins.
                              Sinon, vous pouvez passer par le PluginStore de SketchUcation.
                              Cordialement
                              Inteloide
                              • greenskpG Offline
                                greenskp
                                Default installation is fine but an installation with a custom folder always ask me to install BGSketchup Library.
                                I am using
                                require_all('path\to\custom\folder')
                                inside default plugins folder.
                                  inteloide
                                  Hello,
                                  New version 2.3.9 should correct this issue.
                                  Please download it from the store (with new version of BGSketchup Library)
                                  Inteloide
                                  • greenskpG Offline
                                    greenskp
                                    Thank you!!!
                                    Could you to correct this issue for Component Manager too? Maybe for all BGSketchup family?
                                    • greenskpG Offline
                                      greenskp
                                      inteloid,
                                      sometimes i need to change the tab for make another annotation but the icon of options is very close and opens the window. It's possible to put a delay or increase the distance between the tab name and the icon of options?
                                      Take a look on my screen recorder.
                                      http://i.imgur.com/oJMp2th.gif
                                      • greenskpG Offline
                                        greenskp
                                        Good Evening inteloid,
                                        I did for me a translation pt-br for the file Translation.rb and also correct few things in the file pt-br.js.
                                        If you think this is good, please add for the next update 😄
                                        Translation pt-br
                                          inteloide
                                          Hello Greenskp,
                                          Please find here a new version that include requested improvements.
                                          Please, keep me informed if it's ok for you.
                                          Best regards
                                          Inteloide
                                          Version 2.3.10
                                          • greenskpG Offline
                                            greenskp
                                            Happened some behaviors that not exists in official version. This version 2.3.10 seems incompatible with the library 3.6.
                                            If i make 7 tabs:
                                            • the tab 2 froze
                                            • change the language unfreezes the tab 2 but freezes the tab 6
                                            • From right to left is good but from left to right one tab is skipped
                                            I think is better forget this and only include the translation. Or perhaps force the tab to shrink before of the mouse be released.
                                            custom version 2.3.10
                                            • 6
                                            • 5 / 6
