    [Plugin] Add comments to your file
    104 Posts 20 Posters 25.8k Views 20 Watching
    • JClementsJ Offline
      JClements
      Inteloide, could you paste some screen shoots where you link to a Google Web album photo and and another to a Google Map location? In both Google apps there is a link box where the link can be copied to the clip board. I am unsure if pasting from the pasteboard into Tab dialog field works as you planned or which field it should be pasted into.
      • inteloideI Offline
        inteloide
        Well I don't have a Google web album...sorry
        For a Google map link, I cannot found the field to copy the locailzation, only in the browser web address field, something like : https://www.google.fr/maps/@48.8391153,2.3269406,17z
        You can copy and past this address into the link foeld of the plugin.
        Well, I think tomorrow I will be able to send you a tiny video to explain that.
        Inteloide
        Humanity will do a huge step when the IT professionals will understand that computers are tools...
          JClements
          Hi I,
          Check your personal messages for link info.
          link to specific image
          link to entire album
          • chialiang168C Offline
            chialiang168
            Comments-icon_v2.3.5 Test report
            An error occurred in IE10
            https://dl.dropboxusercontent.com/u/108539326/星野築網頁/004-應用教室/002-sketchup教室/插件應用/Comments(文字註釋)v2.3.5/圖片/Error.gif
            Increase Chinese language file
            Increase China-Taiwan language files
            Dropbox - 404
            (dl.dropboxusercontent.com)
              inteloide
              Hello,
              thank you for translation : I added it to the plugin.
              Please try attached version which should solve your issue, and let me know in order to officially post this version.
              Improvements are :
              2.3.7 Corrected : Avoid menu error
              Optimized : Added chinese languages (thanks to chialiang168)
              2.3.6:	Updated : 	version of ckeditor update to 4.4.5
              		Added :		Change tab key behavior to add spaces (4)
              		Corrected : enter key now make a simple return to line
              Regards.
              Inteloide
              Version 2.3.7
                chialiang168
                https://dl.dropboxusercontent.com/u/108539326/001-Share/022.gif
                  inteloide
                  Lovely!
                    BMoffa
                    I would really like to use this plug-in, but it seems to not save or not load comments that I add. At first it lost comments from one of the two tabs I set up, then it lost everything.
                    I'm using version 2.3.5 in SketchUp 2015 Pro 64 bit (current build). I really hope you can fix this as I really like it.
                      inteloide
                      Hello,
                      Please download version 2.3.7 from the store or from the first post of this thread, and please tell me if solved your issue.
                      Best regards.
                      Inteloide
                        Lê Việt Trường
                        Thank you for this usefull plugin!
                          Lê Việt Trường
                          Hi there,
                          Thanks for the ruby, but where it saves the comments? I lost some tab's comments and can not get it back
                            inteloide
                            Hello Lê,
                            Please download the latest update of BGSketchup Library from the store (version 2.3.1).
                            It may solve your issue.
                            To answer your question, comments are saved inside Model (let's say Inside skp file).
                            If you loose some comment, you can send me your file (even if you delete everyhting inside) and I will try to recover it.
                            Inteloide
                              bharralure
                              Bonjour Inteloide,
                              J’utilise depuis quelques semaines votre plugin "Comments v2.3.7".
                              Il fonctionne correctement sauf qu’à chaque lancement d’un modèle SketchUp comportant des commentaires enregistrés s’affiches les messages tels que les montres les captures d’écrans ci-après :
                              Est-il possible de solutionner ce problème ?
                              Merci.
                                bharralure
                                Bonjour Inteloide,
                                Je viens de solutionner mon problème en installant la version 2.3.2 de BG_Sketchup_Library (j'utilisais la version 2.0.7 sans avoir vu la mise à jour...).
                                Tout fonctionne.
                                  inteloide
                                  Bonjour,
                                  Il vous faut télécharger la dernière version de BGSketchup_Library (la version 2.3.2).
                                  Pour cela, vous pouvez allez, dans Sketchup, dans le menu Extension puis BGSketchup puis BGSketchup update manager.
                                  Là vous tomberez sur l'interface qui vous permettra de mettre à jour vos plugins.
                                  Sinon, vous pouvez passer par le PluginStore de SketchUcation.
                                  Cordialement
                                  Inteloide
                                  • greenskpG Offline
                                    greenskp
                                    Default installation is fine but an installation with a custom folder always ask me to install BGSketchup Library.
                                    I am using
                                    require_all('path\to\custom\folder')
                                    inside default plugins folder.
                                      inteloide
                                      Hello,
                                      New version 2.3.9 should correct this issue.
                                      Please download it from the store (with new version of BGSketchup Library)
                                      Inteloide
                                      • greenskpG Offline
                                        greenskp
                                        Thank you!!!
                                        Could you to correct this issue for Component Manager too? Maybe for all BGSketchup family?
                                        • greenskpG Offline
                                          greenskp
                                          inteloid,
                                          sometimes i need to change the tab for make another annotation but the icon of options is very close and opens the window. It's possible to put a delay or increase the distance between the tab name and the icon of options?
                                          Take a look on my screen recorder.
                                          http://i.imgur.com/oJMp2th.gif
                                          • greenskpG Offline
                                            greenskp
                                            Good Evening inteloid,
                                            I did for me a translation pt-br for the file Translation.rb and also correct few things in the file pt-br.js.
                                            If you think this is good, please add for the next update 😄
                                            Translation pt-br
                                            • 5 / 6
