    Rounded cube problem
    5 Posts 4 Posters 456 Views 4 Watching
    • R
      renegadeandy
      Hi guys am new here but wanting to learn about SketchUp!
      I wanted to create a rounded cube so followed this video guide:
      But my result looks like this :
      http://s27.postimg.org/pv5epo6n3/problemo.jpg
      It seems to go wrong when I "Follow Me" - as seen in the picture the odd meshing of the top components looks wrong - and perhaps is why its broken - but I am not sure where in the video I am making this mistake!
      Please help 😄 🤢
        How big did you make yours? The one in the video is drawn quite large. If it's small, you could run into some issue with overlapping faces at the corners.
        • R
          renegadeandy
          The area of the rounded rectangle is : 15958044 mm² - this is the large one on the right hand side of the image
          • ely862meE
            ely862me
            The image is tiny so it is hard to tell what is going on. But I believe you have made one of the following mistakes :
            1 -your squares are not a square
            2 -the arcs from the corners are not the same size
            Elisei (sketchupper)
            Come and See EliseiDesign
            • Jean LemireJ
              Jean Lemire
              Hi andy, hi folks.
              Click in sequence on the scenes tabs of this SU file for ideas.
              Dice.skp
