    Vray 2.0 service pack is here!!
    renderpluginsextensions
    25 Posts 14 Posters 17.5k Views 14 Watching
    • zdesaynZ Offline
      zdesayn
      hello everyone, i try only now using renderID ang materialID selcted in VFB channel but it's not working.
      http://zdesignviz.blogspot.com/
      • andybotA Offline
        andybot
        are you getting any channels saved? Works fine for me. Are you using the current (second) service release?
        • V Offline
          valerostudio
          I've been using these features for years and never had a problem. What version are you on? 2.0? Anything prior to SP1 on 2.0 did not create the mat ids automatically. You have to go into the material and assign a color.
            albebrigati
            Hello I use vray 2.00.02.
            I can't use VFB channels. I Follow the instructions: select ID COLOR /red for exemple) to material, in the option I select channel MATERIAL ID and in the CUSTOM CHANNEL i ADD CHANNEL. When starts rendering I see the channel of my material specific but it is all black. Why this?
            • andybotA Offline
              andybot
              2.00.02 is not a version number. Should be something like 2.00.25774. You can find the specific build number when you go in Sketchup to Window --> Preferences and look at Extensions list and find vray for SU.
              • 2 / 2
