    Mitsuba House Render
    10 Posts 4 Posters 2.4k Views 4 Watching
    • david57D
      david57
      Trying out the Mitsuba Renderer.
      House model from 3dwarehouse.
        How did you get the render program installed? It seems to be a bit of a fiddle.
        • D
          driven
          @mike
          it used to be a pain, but if you follow the link from here [web 100%,400:zurk17rk]http://sketchucation.com/forums/viewtopic.php?f=323&t=56460#p512606[/web:zurk17rk]
          and instal the plugin, it's so much easier...
          john
          • david57D
            david57
            Mike Amos,
            I exported the sketchUp model using lwo_export.rb.
            I imported that file into Blender and rendered used it
            with Mitsuba Blender Plugin addon: https://app.box.com/s/9vhc30q74hb0ijj26s6j
            Its the same one from this page here:
            http://blenderartists.org/forum/showthread.php?270335-Addon-Mitsuba-Blender-Plugin-%2816-Mar-14%29%26amp;s=44e1534b2cddbbe0ce7fa32bf443205c
            I tried sketchUp addon from SketchUcation site but couldnt get it to work and
            so i just gave up on it.
            • pbacotP
              Lookslike it is all there! How long to cook?
              Looks bright and sharp. Are there soft shadows in this renderer? I looked at the site. Does one need an advanced background to use this renderer? It seems DIY.
              • david57D
                david57
                pbacot,
                It took 49 minutes 58 seconds on a slow single core
                laptop.
                To control soft or sharp shadows you have to adjust
                Sun Radius. See image below.
                  Thanks guys, I have not been able to install the render program itself yet, something about a missing .dll.
                    Any clues, or somewhere I can get help from?
                    • D
                      driven
                      @mike
                      ask over on the other Mitsuba [Plugin] thread, a few people have it running on their PC's,
                      I read that you need a different build if you have legacy a non Intel Core2 or higher...
                      john
                        Thanks John.
