    Plugin Error rp_keyframeanimation.rb Sketchup 2014
    3 Posts 3 Posters 1.0k Views 3 Watching
    • deaneauD
      deaneau
      what i doing wrong?
      tnx dean
      Error Loading File rp_keyframeanimation.rb
      Error: #<SyntaxError: C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/rp_keyframeanimation.rb:18: invalid multibyte char (UTF-8)>
      Error Loading File shapes.rb
      Error: #<SyntaxError: C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:82: syntax error, unexpected ',', expecting =>
      defaults = {"w", 4.feet, "d", 4.feet, "h", 4.feet}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:82: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:82: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:119: syntax error, unexpected ',', expecting =>
      defaults = {"r", 2.feet, "h", 4.feet}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:119: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:119: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:154: syntax error, unexpected ',', expecting =>
      defaults = {"r", 2.feet, "h", 4.feet, "n", 6}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:154: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:219: syntax error, unexpected ',', expecting =>
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:219: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:219: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:272: syntax error, unexpected ',', expecting =>
      defaults = {"r1", 1.feet, "r2", 4.feet}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:272: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:272: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:310: syntax error, unexpected ',', expecting =>
      defaults = {"r", 2.feet, "t", 3.inch, "h", 4.feet}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:310: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:310: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:367: syntax error, unexpected ',', expecting =>
      defaults = {"b", 4.feet, "h", 4.feet}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:367: syntax error, unexpected ',', expecting :: or '[' or '.'
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:367: syntax error, unexpected '}', expecting keyword_end
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:416: syntax error, unexpected ',', expecting =>
      defaults = {"r", 2.feet, "n", 5}
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/shapes.rb:416: syntax error, unexpected ',', expecting :: or '[' or '.'
      Error Loading File wco_addcpoint.rb
      Error: C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/wco_addcpoint.rb:31: syntax error, unexpected ',', expecting ')'
      @@cu_addcpoint = UI::create_cursor (c, 5 , 18);
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/wco_addcpoint.rb:159: invalid multibyte char (UTF-8)
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/wco_addcpoint.rb:159: syntax error, unexpected tIDENTIFIER, expecting ')'
      cmd = UI::Command.new("Konstruktionspunkt hinzufügen...") {
      C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/wco_addcpoint.rb:162: syntax error, unexpected tCONSTANT, expecting end-of-input
      cmd.small_icon = "WCO_ADDCPOINT/icon_addcpoint.png"
      Error: #<SyntaxError: c:/users/d/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/cloud_v8b.rbs:347: Invalid break>
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • J
        Jim
        install the latest version of KeyFrame from here: http://regularpolygon.org/keyframe-animation/download/
        Install the latest version of Shapes from the Extensions Warehouse.
        • TIGT
          These error-messages are indicative of a Plugin version that is incompatible with SketchUp v2014.
          Do NOT copy versions across from older Plugins folders.
          Install fresh versions of your Plugins from the authors' pages or the PluginStore or the EWH...
          Many Plugins have already been updated to be compatible with v2014.
          If you find that a latest version is not compatible with v2014, then let the author know... and a fix might be quickly effected... 😕
