    Letters to gcode
    3 Posts 3 Posters 784 Views 3 Watching
    • W Offline
      wgollie
      Does anyone know if there is a plugin that will convert the letters in sketchup to a format that platscript will translate correctlty to gcode?
        What input file type do you need to give to Platscript? There are several plugins that will export G-code out of SketchUp directly. A Google search will turn up some choices.
          Jim
          Phlatscript, now named SketchUcam, does export to g-code. Use the 3D Text tool to make the letters, and uncheck the Extruded option. I am just assuming you are trying to export 2D screen text..
