    Kerkythea and Sketchup2014
    extensions
    26 Posts 13 Posters 16.8k Views 13 Watching
    • Mistro11M Offline
      Mistro11
      Does anyone use Kerkythea with SU2014? I'm getting a weird toolbar with green faces and the export will not complete. This is happening on my windows 7 Pro 64bit at work.
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
        tomasz
        It works all right here. Can you post a screenshot, please?
        Which version of the SU2KT do you use?
          AirWindSolar
          Working here too. What does it do when the export fails to complete? Taking forever, or crashing? Have you tried exporting something really simple (like a couple of cubes with solid color faces) to see if that works?
          • JQLJ Offline
            JQL
            Those green faces use to happen when SU can't find the icons. You probably have the plugin installed incorrectly.
            www.casca.pt
            Visit us on facebook!
            • Mistro11M Offline
              Mistro11
              I agree it must be the way I installed the plugin. I am new to windows 7. I figured when I run the export for the first time, all I had to do was point to Kerkythea application. But that's when I got the error and don't know what it means.
              The error message
              Error
              The green faces
              the green faces
              I have the plugin in AppData/Roaming/Sketchup2014/Sketchup/Plugins
              • Mistro11M Offline
                Mistro11
                I got this reply from Fletch over at Kerkythea forums:
                As far as I'm aware, no plugin will work for SU2014 without an update for proper path installation, SU2014 Ruby is also an update, so all plugins must be updated.
                So, until Tomasz releases an update, there is no SU2KT for SU2014
                If this is true, how are you guys getting it to work?
                • JQLJ Offline
                  JQL
                  I use Thea now. I'm going to install Kerkythea and get back at you.
                  www.casca.pt
                  • JQLJ Offline
                    JQL
                    It's working better than ever.
                    Erase everything in SU 2014 Plugins folder related to SU2KT (it's no longer on c:\programs (x86)...\Sketchup\plugins\
                    Now everything is in:
                    C:\Users\YOUR-USER-NAME-GOES-IN-HERE\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins\
                    No go here and download a zip file.
                    http://www.kerkythea.net/cms/index.php/downloads/software
                    Fastest way to install is to turn your SU2KT3.17+.zip into SU2KT3.17+.rbz, by simply changing extension name.
                    Then go to sketchup and in the window menu > preferences > extensions > install extension choose the file you turned into rbz.
                    It should be working fine now...
                    www.casca.pt
                    • GarethG Offline
                      Gareth
                      I have changed the folder from .zip to .rbz. but I can't get the folder to show as a selection when I click 'Install Extension'.
                      All other plugins have installed successfully into SU2014 over the past day, but KT is giving me a bit of grief....!!
                      • Mistro11M Offline
                        Mistro11
                        JQL I will try that method when I get back to the studio tomorrow.
                        • BoxB Offline
                          Gareth, are you sure you are looking in the right place for the file that you downloaded and that you have renamed the file extension correctly? I have just downloaded it from the link above, changed it to .rbz and it installed perfectly into 2014.
                          • GarethG Offline
                            Gareth
                            Yep...it's in the same place as my other downloaded plugins.
                            I can see it when I open the folder with all the others in there, but it isn't there when I use the extensions from within SU.
                              tomasz
                              Fletch is simply wrong. 😡
                              It all works here. It works even better, because you don't need administrator rights anymore.
                              You haven't installed the plugin correctly. The missing icons mean that you haven't copied 'su2kt' folder. Do not use "C:\ProgramFiles(x86)" folder! This is why it fails. SU2014 plugins should be installed in the User folder:
                              "C:\Users<YourUserName>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins"
                              Check the screen-shot below, please.
                              Have you installed 3.17+ form Kerkythe website?
                              Have you extracted/copied su2th folder as well?
                              When you export and open the exported file automatically for the first time, the plugin will ask you for selecting thea.exe. If you do this correctly, the exported file will be opened and the path to Kerkythea stored in kt_path.txt, as shown in the screen-shot.
                              Sofie got beamed up and looks all right.
                              User roaming folder
                              • JQLJ Offline
                                JQL
                                "Sophie got Beamed up and looks alright"
                                LOL a bit flat if you ask me...
                                www.casca.pt
                                • GarethG Offline
                                  Gareth
                                  All is good now....
                                  the "**C:\Users<YourUserName>\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins**" worked a treat
                                  Thank you...!!
                                  ...life should be easier than this 😆
                                  • Mistro11M Offline
                                    Mistro11
                                    Turns out my issue is similar to someone else who posted it over at KT forums
                                    http://www.kerkythea.net/forum/viewtopic.php?f=10%26amp;t=10502
                                    I even installed my free version 8 on the W7 machine and it's the same issue, so not a 2014 specific thing. The plugin works fine on my XP machine but not working in W7. It seems I have some kind of permissions configuration thing going on but at least I can create the xml file and open seperately in KT. Any ideas?
                                      tomasz
                                      Have you extracted 'su2kt' & su2kt.rb files to the User folder?
                                      If so, the files in the folder don't require admin permission.
                                      Delete kt_path.txt if the 'su2kt' folder. This should help.
                                      • X Offline
                                        xlu73
                                        Bonjour j'essaie d'installer kerkythea pour sketchup pro 2014 mais sketchup ne reconnait pas les plugins de kerky. Cela fonctionnait pourtant très bien avec les versions antérieures de SU. Quelqu'un aurait-il une solution?
                                        D'vance merci,
                                        Xavier.
                                        • FrederikF Offline
                                          Frederik
                                          Comme il s'agit d'une communauté internationale et comme vous pouvez voir la plupart sont écrites en anglais, je vous conseille de bien vouloir écrire en anglais...
                                          D'vance merci
                                          Cheers
                                          Kim Frederik
                                            LUSO1708
                                            How do I install the plugin to export from sketchup 2014 to kerkythea on mac?
                                            • 1 / 2
