    Reflections on a wire fence
    renderpluginsextensions
    6 Posts 4 Posters 575 Views 4 Watching
    • ToboboT Offline
      Tobobo
      This might not be possible, but I want to create a fence texture for a wire fence with reflections. I have a lot of fencing to model so I want to use a flat face with textures.
      I can get the transparencies right so only the wire sections render but I want only the wire surface to have reflections.
      But when I add the reflection layer it doesn't follow the alpha channel and puts a reflection across the whole face the texture is applied to.
      The image below is a test. the back ground is red to make sure the transparencies are working.
      the one on the right is with out reflection and the left has Fresnel reflection applied.
      Any ideas?
      Toby
      Philippians 4:13
        rspierenburg
        I think your best bet would be to use a reflective metallic material (ie Chrome) and then use your fence texture (black and white version) as a diffuse mask on top. That way only the area that the fence texture shows will be reflective.
        Rob
        • ToboboT Offline
          Tobobo
          Rob
          That's a good idea Rob, I'll try it πŸ‘
          Toby
          Philippians 4:13
          • BoxB Offline
            I'm no help on this but your subject would make a perfect title for some banal modern art piece.
            • andybotA Offline
              andybot
              Just a small detail - you need to make sure you put your alpha mask at the "perpendicular" material in the fresnel reflections. Otherwise, you will have a reflection over the whole face. With the diffuse mask, only the diffuse layer will be transparent.
              You could also try a normal map or bump map to try and get the reflections going in different directions on the wire.
              • ToboboT Offline
                Tobobo
                thanks Andy, I'll have a look into that.
                EDIT
                Andy,
                That worked a treat!!!! 🀣 😍
                Toby
                Philippians 4:13
