    Upgrading plugins to Ruby 2.0 for SketchUp 2014
    43 Posts 7 Posters 9.4k Views 7 Watching
      marksup
      Hopefully Ruby experts can comment on and append to this topic to create a useful overview of what has changed and needs to be recoded. (Or perhaps there is a useful website page somewhere that already provides this information?)
      Syntax...
      Support for retry within a loop has been dropped.
      Support for same line assignment for case - when (using a colon) has been dropped.
      RUBY_PLATFORM... Note that (for windows) this variable value has changed.
      Operation...
      "A"[0] no longer returns the ANSI integer. Use "A".unpack("c")[0] instead.
      ["A","B","C"].to_s is now ineffectual. Use ["A","B","C"].join("") instead.
      Character coding...
      I am currently still trying to solve many "Invalid multibyte char (UTF-8)" errors, for currency symbols, [sup:ym2kwl6a]2[/sup:ym2kwl6a], [sup:ym2kwl6a]3[/sup:ym2kwl6a] and any foreign characters. I have found a $KCODE variable (previously set to UTF8), but which now unfortunately is apparently no longer supported. More expert advice on this issue would be very helpful.
      • jolranJ Offline
        jolran
        This topic should be made sticky and simply called "Upgrading plugins to Ruby 2.0", in my opinion.
          ANSI encoded script files will break Ruby2, but were 'tolerated' by earlier versions...
          Use Notepad++ and ensure the rb is saved encoded as UTF8-without-BOM.
          Redo any now incorrect m ² etc to suit UTF [just type/paste the 'special character'].
          • tt_suT Offline
            tt_su
            @marksup said:
            I am currently still trying to solve many "Invalid multibyte char (UTF-8)" errors, for currency symbols, [sup:1uu9cl7i]2[/sup:1uu9cl7i], [sup:1uu9cl7i]3[/sup:1uu9cl7i] and any foreign characters. I have found a $KCODE variable (previously set to UTF8), but which now unfortunately is apparently no longer supported. More expert advice on this issue would be very helpful.
            Save your RB files in UTF-8 encoding. For compatibility with older Ruby save without the BOM mark.
            The "Invalid multibyte char" is probably due to files being saved in ANSI format. The bytes in ANSI from 127-255 is not compatible with UTF-8 where they represent control characters.
              marksup
              Upgrade addition...
              Hash-array indexhas been replaced by key...
              key = ( Sketchup.version.to_i > 13 ) ? hash-array.key(value) : hash-array.index(value)
              re: Encoding...
              I have tried notepad++ Encoding convert to UTF-8 without BOM but now get...
              Error: #<Encoding::CompatibilityError: incompatible character encodings: UTF-8 and ASCII-8BIT>
              Also, what might a (newly supported) unicode string look like?!
                Once you have converted your script file to UFT8-without-BOM and saved [don't just view it with that encoding - it needs converting!]... then you need to replace earlier special characters [if any] in it that are no longer compatible.
                Simply retype the desired text and it should encode properly e.g. m²
                • tt_suT Offline
                  tt_su
                  @marksup said:
                  Upgrade addition...
                  Easier to just use key as that works on both versions. Less code branching.
                  @marksup said:
                  re: Encoding...
                  Can you provide context around this error.
                  It should look like anything different, but under the hood, all characters that is outside the ASCII range (0-127) will be multi-byte characters.
                    marksup
                    Hi TT,
                    Are you sure about key (and not key?) being valid previously...
                    ha = {"A"=>"ABC"}
                    ha.key("ABC")
                    Error: #<NoMethodError: undefined method `key' for {"A"=>"ABC"}:Hash>
                    (eval)
                    • tt_suT Offline
                      tt_su
                      @marksup said:
                      Hi TT,
                      ha = {"A"=>"ABC"}
                      ha.key("ABC")
                      (eval)
                      Ah! My bad, I misread that. I stand corrected.
                        Brighter3D
                        Win32API.so seems to no longer works on SU2014, instead we should use build in Win32API.rb.
                        When passing
                        Sketchup.active_model.skpdoc
                        pointer,
                        I've got error:
                        Error: #<TypeError: no implicit conversion of Fixnum into String>
                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:23:in pack' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:23:in block in call'
                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in each' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in each_with_index'
                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/Win32API.rb:22:in call' C:/Users/l/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/BrighterSU/BrighterSU.rb:68:in mydll_render'
                        C:/Users/l/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/BrighterSU/BrighterSU.rb:248:in block in InitToolbar' -e:1:in call'
                        funciton definition:
                        BRrender = Win32API.new(mydll,"RenderScene",["P","P","I","I","I"],"I")
                        function call:
                        BRrender.call(Sketchup.active_model.skpdoc,Sketchup.active_model.path,width.to_i,height.to_i,nFromSett.to_i)
                        Is it because of SU 64bit version?
                        Does anyone have similar problem or anyone succeed to pass
                        Sketchup.active_model.skpdoc pointer into c++ dll with SU2014?
                        • tt_suT Offline
                          tt_su
                          @brighter3d said:
                          When passing
                          pointer,
                          I've got error:
                          function call:
                          SketchUp is still 32bit.
                          The error you are getting is from the Win32API module. Seems to not like it that you feed it integer. It's expecting strings. Maybe you'll get some hints if you dig into Win32API.rb at the line number that raised the error. This Win32API compatibility shim might not be 100% compatible with the old Ruby 1.8. I'm not sure how much it changed between Ruby 1.8 and Ruby 2.0.
                            Brighter3D
                            What a pity, I thought this version is 64bit already 😞.
                            There is still no possibility to load 64bit's dlls 😞.
                            Thank you, you put my thoughts into right direction.
                            changing
                            into
                            BRrender = Win32API.new(mydll,"RenderScene",["I","P","I","I","I"],"I")
                            solves the problem.
                            Looks like "P" is char* now, and "I" can be int or void*...
                            • tt_suT Offline
                              tt_su
                              Yea unfortunately it's not. I know it's a pain for render engines. The workaround would be to use a 64bit helper process to host the render engine.
                              changing
                              into
                              solves the problem.
                              Oh good! Glad that worked. I think there has been some tweaks made between Ruby 1.8 and 1.9 in that respect.
                                marksup
                                I have written a CSV format file SketchUp Importer which includes the following lines...
                                File.foreach(csv_filepath) do |file_data|
                                next if file_data.match(/\A#/)
                                The CSV file includes the following comment line: # Room-Name, Floor Nr, Area m², Length
                                Sketchup 2014 Bugsplats on processing the CSV file (at the match statement) if it is not UTF-8 encoded and includes the squared character.
                                Does this need to be fixed by SketchUp and/or is there anything I can do to detect/avoid the issue (since I can not control either the selected CSV file content or its encoding)?
                                These UTF-8 errors are insidious, and a definitive guide to their avoidance would be very helpful. What have other Ruby programmers been doing (prior to SketchUp 2014) to adjust to the new Ruby version?, are there no existing resources?
                                • tt_suT Offline
                                  tt_su
                                  Bugsplats should not happen and is something we should fix. Have you submitted the splats? With any information we can use to look it up?
                                  If you search on Ruby in general, without the context of SketchUp, you find a number of articles and forum posts with people migrating from Ruby 1.8 to 1.9/2.0.
                                  The bugsplat here is troublesome, because it should just raise an error. If it had raised an error you would have been able to try again with a different encoding. Now, I haven't read arbitrary files with ruby yet, but I would have thought there would be a methods in the Ruby StdLib to detect encoding of a given string/file?
                                  Back to the bugsplat, can you provide a small snippet that reads a file and a file that will cause it to crash? Smallest possible snippet to reproduce this?
                                    If the .CSV file is not in UTF8-without-BOM encoding, but say ANSI, and also since it may include characters like 'm²', these both might cause you issues.
                                    It's easy enough to [re]encode any file appropriately using Notepad++.exe...
                                    However if the 'm²' were typed in say Unicode, then it might then be converted to a strange looking character combo when re-encoded.
                                    In that case you need to retype the character[s] and it should convert automatically to display in UTF8 encoding...
                                    Save and retry.
                                    Of course, the .RB file itself must of course be properly encoded as UTF8-without-BOM to be compatible with v2014's Ruby2.0, and remember that any special characters [like 'm²'] which you had in any earlier encoding might have to be corrected if already UTF8 compliant... as outlined above...
                                      marksup
                                      Notepad++ is great, but customers of plugins can not be expected to use it to investigate and correct the encoding of their data files.
                                      Is the encoding of a scrambled Ruby file significant? - since a scrambled UTF-8 .rb is reported by Notepad++ as ANSI.
                                        It is unfortunate that the encoding of a PC's plain Notepad file is in ANSI.
                                        However a txt/csv file made in Excel or through a Ruby script should be encoded as compatible UFT8-without-BOM...
                                        If you have made the RBS from an incorrectly encoded RB it will fail in v2014.
                                        If you make the RB correctly encoded than encrypt the RBS from that is should be compatible.
                                        What Notepad++ sees the contents as is somewhat academic as isn't it a binary file ?
                                        Files encoded as UFT8-without-BOM should be compatible with v2014 Ruby2.0 AND all earlier versions of SketchUp and their Ruby version...
                                        You could try trapping for the Sketchup.version >= 14 then re-encoding the string got from any data file.
                                        You should still be able to 'read' the contents of an ANSI encoded data file [or any type of data file - even binary is 'readable'], but to then use that string in Ruby2.0 you probably need to force some recoding...
                                        if Sketchup.version.to_i >= 14
                                          lines = IO.read(csv_file_path).force_encoding('UTF-8')
                                        else
                                        lines.split("\n").each{|line|
                                          ### process the line...
                                        I typed this without reference and it is untested, but you get the idea...
                                        • Dan RathbunD Offline
                                          Dan Rathbun
                                          Making the first statements of the block:
                                          if defined?(Encoding)
                                            file_data.encode!("UTF-8") unless file_data.encoding == Encoding;;UTF_8
                                          I'm not here much anymore.
                                          • tt_suT Offline
                                            tt_su
                                            You could try to open the file as ASCII-8bit - then attempt to convert the data afterwards. But in general you need to know what encoding a file is in. You'll see editors often provide this option, even Notepad.
                                            After reading the file as ASCII-8bit - which is in effect what Ruby 1.8 did - then you could try to change the encoding to UTF-8 - if that fails it's a good chance the file is ANSI encoded in which you can retry with that. (Though there are many variants of ANSI, US-ANSI is most normal one.)
                                            As for the crashes - as I mentioned, that should not happen. Did you submit those report? This is important for us in order to address the crash.
                                            • 1 / 3
