    Vray not rendering the majority of the model
    renderpluginsextensions
    2 Posts 2 Posters 355 Views 2 Watching
      MandanaGMP
      Hello,
      I have been researching this issue for a few days now, and have tried several solutions.
      When I render my Sketchup model with Vray, only the windows are rendered.
      I have placed everything on the 0 Layer, un-grouped everything, and copied and pasted the model into a new Sketchup file. The last technique works, but only once or twice, after which, it simply renders only the sky, and NONE of the model.
      I hope someone has another solution!
      Thank you-
      Sketchup 8
      Vray 2.0
      Windows 7
      • andybotA Offline
        andybot
        @mandanagmp said:
        Hello,
        Thank you-
        Sketchup 8
        Vray 2.0
        Windows 7
        If you're using vray 2.0, you should see a progress window come up. Are there any errors that show up there? Look specifically if there are materials that are failing to load.
