    Using Materials dynamically
    3 Posts 2 Posters 1.4k Views 2 Watching
    • C
      CaptLogic
      Hello,
      I'm trying to create a dynamic component that mimics the functionality of the 'Art Frame' dynamic component that Google created. Basically it is a dynamic component of a frame picture. Each time you click on the frame the 'artwork' material changes.
      If I understand correctly, this behavior comes from the components 'onClick' behavior that is currently: SET("ArtCount",1,2,3,4)
      To me this says, rotate the material between 4 different options.
      What I cannot figure out is how to create this to begin with. I see a 'Custom' section in the components attributes section that has a 'ArtCount' property that is set to '4'. What I don't understand is how to designate each material. Is it a hidden face that has a tag that identifies it as item #1 or 2 and is unhidden in response to a 'dynamic click'?
      I'm happy to absorb a video or other tutorial, I just can't seem to find what I'm looking for.
      Thanks so much.
      • J
        Jim
        It's not a hidden face exactly - there are 4 sub-components which are being made visible/hidden depending on the value of the ArtCount attribute.
        The onClick is just cycling the value of the ArtCount attribute through 1 - 4. Nothing more to the onClick than that.
        Then each of the 4 Components which contain the images looks at the value of ArtCount to decide to be hidden or visible. These 4 components use the built-in HIDDEN attribute to decide to be hidden or visible.
        "Mona" Component:
        Hidden: =IF(ROUND(PictureFrame!ArtCount)=1,FALSE(),TRUE())
        means if ArtCount equals 1, then Hidden is FALSE, and Mona is visible.
        • C
          CaptLogic
          Awesome,
          Thanks for your help.
