    Plugin "Beam Tool"
    3 Posts 3 Posters 587 Views 3 Watching
    • HumpmetwiceH Offline
      Humpmetwice
      One of my favorite plugins. I use it almost every time I open Sketchup but since a computer change I get the error in the image attached. Same operating system sketchup versions and all.Works great on one and not the other.I attached the plugin as well. Any help would be greatly appreciated!
      beamtool.zip
      • cottyC Offline
        cotty
        Did you have a look at the folder if the mentioned file is there?
        my SketchUp gallery
          If it's not in the folder, look in the original installation set, and reinstall from scratch.
          BUT firstly also check that the new computer has FULL permissions set to the Plugins folder - Windows might have prevents some files being auto-installed, you need FULL permissions...
          See here... http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
          You can also get that .so file from SCF...
          http://sketchucation.com/forums/viewtopic.php?p=380121#p380121
          Make sure you use the right one.
          Since you choose not to share your OS/version with use, please read the notes about usage and which version of the .so is needed for which Ruby etc...
