    Inputbox too narrow
    12 Posts 5 Posters 872 Views 5 Watching
    • G Offline
      Garry K
      I've been working with a few different languages and the sketchup inputbox.
      My computer is setup with english.
      Everything is working just fine in French.
      The problem is when I supply prompts and lists in russian.
      The prompts look ok but there isn't sufficient room and the text cuts out.
      The lists don't look good at all - I just see a bunch of vertical bars.
      • P Offline
        pgarmyn
        @Garry
        You didn't precise: What inputbox?
        In case its your Ruby code:
        Try to use a longer default value : Use or add spaces at the end.
        It could be that you will also have to add a point at the end of the spaces.
        • G Offline
          Garry K
          It is the Sketchup API inputbox that I am referring to. Adding spaces and possibly a period at the end is really not a very good solution.
          English - OK
          French - OK
          Russian - doesn't fit ( how many spaces )
          Chinese - or some other language ( how many spaces )
          Would it be better if I converted this over to a web dialog.
          • TIGT Online
            Also make sure that your .rb script is saved as a UTF-8 without BOM encoded text file.
            It's a simple option if you use Notepad++.exe to edit it...
            But padding the strings with spaces is often the only way to get everything into an inputbox drop-down/text-area or left-side-prompt.
            Using webdialogs allows you greater flexibility in format and user interaction, but again if you specify fixed width areas for anything containing text, then it will crop [or wrap - depending on your css etc] your longer strings - especially as might happen in 'translated strings'...
            So you will still need to test every dialog in every language to spot unexpected glitches... šŸ˜’
            • G Offline
              Garry K
              I've got Russian working.
              Initially I ran into a problem where the last item in a list just showed up as a bunch of vertical lines. So I tried adding another pipe symbol at the end and it worked.
              d_options = @@options_t.collect.join('|') + '|'
              Will Chinese work the same way? Or will it not fit into UTF-8?
              • P Offline
                pgarmyn
                😮 usefull
                • G Offline
                  Garry K
                  I have a number of languages translating just fine.
                  I open up my dictionary template in Notepad++ and save it in the appropriate language using UTF-8 without BOM.
                  With French, Russian, icelandic everything works well.
                  With Chinese I just see a bunch of boxes.
                  How can I test - is there something special to make use of Chinese fonts? Do I have to install a Chinese version of Sketchup? Is there something else that I am missing.
                    driven
                    your default font needs to be one with the extended char set that includes the Chinese dialect your writing in... [for you to see them]
                    Lucida Console is a reported to be pretty good [monospaced] all-rounder or Arial [Pro] is not to bad if you have it...
                    been looking into the same things myself...
                    john
                      slbaumgartner
                      UTF-8 is a variant of Unicode, and definitely supports Chinese. However, as @driven pointed out, the display font you are using must also handle the extended character codes used by Chinese.
                      Steve
                        driven
                        looking at PC specific fonts it seems that Lucida Console may not include Chinese characters... so sorry about that advice...
                        OT [ish] On mac when using rich text you get some automatic font substitutions that build 'char sets' for missing bits.
                        On one occasion when trying to translate a Russian plugin it really did my head in when I tried to copy paste back into the webdialog's html...
                        john
                        • G Offline
                          Garry K
                          I've now got it working.
                          Here are some examples using the inputbox for my Door Maker.
                          My next job will be to get this to work inside web dialog.
                          I understand that I will need a metatag - I'm hoping for the best.
                          People who actually use these languages will probably laugh at the straight translations. Since I don't understand the various contexts - I'm hoping for a bit of help.
                          But at least this is a start - and I know that the code works without having to make any changes.
                          English Door Maker
                          French Door Maker
                          Russian Door Maker
                          Chinese Door Maker (traditional)
                          • G Offline
                            Garry K
                            I've now made a simple video of the door maker.
