    My furniture
    139 Posts 24 Posters 29.4k Views 24 Watching
      You have the exact measures when you start your model or it's by eyes?
      • ginchiusG Offline
        ginchius
        @pilou said:
        :fro:
        At the beginning it was a normal sized armchair, later I decided to resize it according to this little man (attached image). H860 x W600/1285 x D835 mm
        You can find my models at http://sketchucation.com/shop/models
        • I Offline
          infernovak
          Amazing models man! Really cool! I've been drooling over them
          Could you share some tips on how you create the piping or seams in your models? Perhaps some images or a video, before you smoothen it out?
          • ginchiusG Offline
            ginchius
            Thanks,
            All seams/pipes are added after smoothig with this plugin "Pipe along path"
            Just mark the lines/edges where you want to add the pipes (make sure that selected lines/edges are not softened/smoothed) or make a "road" for piping with "SketchUV: path select tool"iping with "SketchUV: path select tool"
            • I Offline
              infernovak
              That's a wonderful way to do it. Will try it out!
              I also noticed in your models that there is a clear and distinct dark line when 2 edges of the fabric meet. It looks really clean!
              How you achieve that effect? Is it in the geometry or done using a plug-in after smoothing?
              • ginchiusG Offline
                ginchius
                If you are talking about these lines (see attached image with red marks) so it's a tubes/seams.
                • I Offline
                  infernovak
                  I was referring to your Madison sofa model, labeled as 1,2,3
                  1 - The small, horizontal joint in the armrest
                  2 - Similar joint running along the arm
                  3 - The cuts in the tufting part
                  • ginchiusG Offline
                    ginchius
                    1 and 2 - pipes
                    • pbacotP Offline
                      Thanks for the details!
                      • I Offline
                        infernovak
                        Thanks for sharing these tips! They are amazing πŸ˜„
                        You should consider doing your own Youtube channel for 3d Modelling in Sketchup. Trust me, a lot of beginners like me would look up to your work for inspiration!
                        • I Offline
                          infernovak
                          @ginchius said:
                          1 and 2 - pipes
                          In #3, how were you able to fuse the piping into the fabric? I am trying to test how it happens but it destroys the model.
                          Here is what I am trying:
                          1. Select path, add pipe
                          2. explode pipe out of group, so that it merges with model
                          3. Smooth and subdivide
                          What am i doing wrong here?
                          • ginchiusG Offline
                            ginchius
                            Leave the pipes in group, do not explode them. Attached an example.
                            Seat cushion 2.skp
                            • I Offline
                              infernovak
                              Thank you for sharing this. Will test it out!
                                cuttingedge
                                ginchius , I really like your models, they are so neatly done. It appears in your models that you like to use artisan (with tris) than Subd (with quads). Do you find it more practical to use tris than quads in SU at least for upholstered furniture?
                                • ginchiusG Offline
                                  ginchius
                                  Modeling with Artisan is much easier and faster than with SubD. No need to worry about quads.
                                  Also, Artisan has a few imortant tools for me: Sculpt tool is very useful for adding some wrinkles to make furniture look more realistic. Crease tool is very important for me...
                                    About the apply texture...
                                    Some UV or not ? And with what prog ?
                                    • ginchiusG Offline
                                      ginchius
                                      "SketchUV" and "Roadkill UV tool 1.1" https://www.youtube.com/watch?v=NXS6_WdXZ3s
                                      and sometimes using "Fredo ThruPaint"
                                        rv1974
                                        Great work! Have you thought about Marvelous Designer?
                                        • ginchiusG Offline
                                          ginchius
                                          A great software, had to use a trial version. It's easy to make a simply pillows with this softwre.
                                          • 6
                                          • 7
                                          • 7 / 7
