    My furniture
    139 Posts 24 Posters 41.4k Views 24 Watching
    • I
      infernovak
      Thanks for sharing these tips! They are amazing πŸ˜„
      You should consider doing your own Youtube channel for 3d Modelling in Sketchup. Trust me, a lot of beginners like me would look up to your work for inspiration!
      • I
        infernovak
        @ginchius said:
        1 and 2 - pipes
        In #3, how were you able to fuse the piping into the fabric? I am trying to test how it happens but it destroys the model.
        Here is what I am trying:
        1. Select path, add pipe
        2. explode pipe out of group, so that it merges with model
        3. Smooth and subdivide
        What am i doing wrong here?
        • ginchiusG
          ginchius
          Leave the pipes in group, do not explode them. Attached an example.
          Seat cushion 2.skp
          You can find my models at http://sketchucation.com/shop/models
          • I
            infernovak
            Thank you for sharing this. Will test it out!
            • C
              cuttingedge
              ginchius , I really like your models, they are so neatly done. It appears in your models that you like to use artisan (with tris) than Subd (with quads). Do you find it more practical to use tris than quads in SU at least for upholstered furniture?
              • ginchiusG
                ginchius
                Modeling with Artisan is much easier and faster than with SubD. No need to worry about quads.
                Also, Artisan has a few imortant tools for me: Sculpt tool is very useful for adding some wrinkles to make furniture look more realistic. Crease tool is very important for me...
                  About the apply texture...
                  Some UV or not ? And with what prog ?
                  • ginchiusG
                    ginchius
                    "SketchUV" and "Roadkill UV tool 1.1" https://www.youtube.com/watch?v=NXS6_WdXZ3s
                    and sometimes using "Fredo ThruPaint"
                      rv1974
                      Great work! Have you thought about Marvelous Designer?
                      • ginchiusG
                        ginchius
                        A great software, had to use a trial version. It's easy to make a simply pillows with this softwre.
                        • 7 / 7
