    My furniture
    139 Posts 24 Posters 38.7k Views 24 Watching
    • I Offline
      infernovak
      @ginchius said:
      @infernovak said:
      That's a wonderful way to do it. Will try it out!
      I also noticed in your models that there is a clear and distinct dark line when 2 edges of the fabric meet. It looks really clean!
      How you achieve that effect? Is it in the geometry or done using a plug-in after smoothing?
      If you are talking about these lines (see attached image with red marks) so it's a tubes/seams.
      I was referring to your Madison sofa model, labeled as 1,2,3
      1 - The small, horizontal joint in the armrest
      2 - Similar joint running along the arm
      3 - The cuts in the tufting part
      • ginchiusG Offline
        ginchius
        1 and 2 - pipes
        You can find my models at http://sketchucation.com/shop/models
        • pbacotP Offline
          Thanks for the details!
          • I Offline
            infernovak
            Thanks for sharing these tips! They are amazing πŸ˜„
            You should consider doing your own Youtube channel for 3d Modelling in Sketchup. Trust me, a lot of beginners like me would look up to your work for inspiration!
            • I Offline
              infernovak
              @ginchius said:
              1 and 2 - pipes
              In #3, how were you able to fuse the piping into the fabric? I am trying to test how it happens but it destroys the model.
              Here is what I am trying:
              1. Select path, add pipe
              2. explode pipe out of group, so that it merges with model
              3. Smooth and subdivide
              What am i doing wrong here?
              • ginchiusG Offline
                ginchius
                Leave the pipes in group, do not explode them. Attached an example.
                Seat cushion 2.skp
                • I Offline
                  infernovak
                  Thank you for sharing this. Will test it out!
                    cuttingedge
                    ginchius , I really like your models, they are so neatly done. It appears in your models that you like to use artisan (with tris) than Subd (with quads). Do you find it more practical to use tris than quads in SU at least for upholstered furniture?
                    • ginchiusG Offline
                      ginchius
                      Modeling with Artisan is much easier and faster than with SubD. No need to worry about quads.
                      Also, Artisan has a few imortant tools for me: Sculpt tool is very useful for adding some wrinkles to make furniture look more realistic. Crease tool is very important for me...
                        About the apply texture...
                        Some UV or not ? And with what prog ?
                        • ginchiusG Offline
                          ginchius
                          "SketchUV" and "Roadkill UV tool 1.1" https://www.youtube.com/watch?v=NXS6_WdXZ3s
                          and sometimes using "Fredo ThruPaint"
                            rv1974
                            Great work! Have you thought about Marvelous Designer?
                            • ginchiusG Offline
                              ginchius
                              A great software, had to use a trial version. It's easy to make a simply pillows with this softwre.
                              • 7 / 7
