    Between different Macs plugin works and doesn't work
    48 Posts 6 Posters 3.0k Views 6 Watching
      mwm5053
      Yes Garry I deleted the other one and installed the the new one.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        slbaumgartner
        @garry k said:
        Just to be sure - you downloaded the latest dialog_test.rb and line 10 now says:
        @dlg.allow_actions_from_host( 'cabmaker32.com/' );
        Trailing slash not needed. Just 'cabmaker32.com'
          Remove the final / in the domain name. 😕
          • G Offline
            Garry K
            Jeff and Walt
            I have now removed the trailing slash from cabmaker32.com on line 10
            Maybe this will work.
            Please try it
            cleaned up the domain address
              mwm5053
              Got the same error, sorry wish I could be of more help
              2011 iMac
              V2 Twilight
                slbaumgartner
                Walt,
                Do you have the WebKit inspector activated? If not, please open a Terminal window and type
                defaults write <bundleid> WebKitDeveloperExtras -bool true
                where you replace <bundleid> with:
                com.google.sketchupfree8 for v8 Free
                com.google.sketchuppro8 for v8 Pro (what your info says you have)
                com.sketchup.SketchUp for 2013
                After doing that, please run Garry's test script and while the WebDialog labeled "connect to website" is still open, right-click on it and select "Inspect Element" from the popup menu. This will open the WebKit Inspector. The GUI of the WebKit Inspector has changed with version, but look for something labeled "Console" and click it. Please let us know if the Console displays any error or warning messages.
                Steve
                  mwm5053
                  @ Steve When I right click in Connect to Website all I get is "Reload" but this is what Terminal looks like after pressing return in terminal was that right?
                  2011 iMac
                  V2 Twilight
                    slbaumgartner
                    The Terminal screenshot looks as if you left off part of the command. Did you type the entire line
                    defaults write com.google.sketchuppro8 WebKitDeveloperExtras -bool true
                    I forgot to mention that before entering this command you should quit SketchUp and restart it afterward. Until the default takes hold the right-click menu will only contain "Reload".
                    Steve
                      mwm5053
                      I double checked the terminal and retyped and restated SU still no right click web inspector?
                      2011 iMac
                      V2 Twilight
                        slbaumgartner
                        Missed it again! You typed com.google.sketchup8pro, it should be com.google.sketchuppro8
                        Steve
                          mwm5053
                          2011 iMac
                          V2 Twilight
                            mwm5053
                            I don't understand why right click won't bring up Inspect Element?
                            2011 iMac
                            V2 Twilight
                              slbaumgartner
                              Still typing the command wrong!
                              t space between Extras and -bool
                              [edit] Ack, that didn't format right! You left the t out of Extras and attached the - to its end instead of to the front of -bool.
                                mwm5053
                                Ya not a very good typist sorry is this right
                                2011 iMac
                                V2 Twilight
                                  slbaumgartner
                                  That appears to be right. Did it work?
                                  I'm turning in for the night in a minute. Will check back tomorrow.
                                  Steve
                                    mwm5053
                                    still no inspect element on right click
                                    2011 iMac
                                    V2 Twilight
                                      mwm5053
                                      Ok this AM I had Safari open with Inspect Element open on a web page just to see what it did and opened SU and clicked on Web Dialog Test and right clicked on Connect to Website and Web Inspector popped up with this. Now what? I'll be here for a while then off to work for the day will check back.
                                      Walt
                                      2011 iMac
                                      V2 Twilight
                                        slbaumgartner
                                        Walt
                                        That's more like it! I wonder what was wrong before...
                                        Anyway, click on the console button and show me what it displays then. In particular, if there are any warning or error messages. The little red symbol at the bottom makes me think there was a error reported.
                                        Steve
                                          mwm5053
                                          Evidently Inspect needs to open in Safari eo get Web Inp. to popup but here it is.
                                          2011 iMac
                                          V2 Twilight
                                            slbaumgartner
                                            OK! My cross-domain security theory confirmed!
                                            What's happening is that when the html is loaded directly, the document's domain is empty (null). The XMLHttpRequest security won't allow load from some other domain. I can verify that the domain is also empty on my Mavericks box, so this implies that they added a special case for null domain in the security rules after the WebKit version that comes with Lion (or perhaps modified the domain to be an empty string instead of null).
                                            Steve
                                            [edit] The typeof document.domain on my Mavericks box is a string, "". They fixed it so that a locally loaded html gets an empty string domain instead of null.
                                            • 2 / 3
