    Dynamic Component - Need Help w/OnClick Rotation
    3 Posts 2 Posters 1.8k Views 2 Watching
    • mooarchiM
      mooarchi
      Hi Guys:
      I am trying to add the OnClick Behavior to the left and right doors of this component. The left door moves away from its hinge position when rotating. And the left door has a mind of its own. I would like one (1) door to open 90-degrees to the left and one (1) door to open 90-degrees to the right.
      Kindly help! If you could set the attributes and upload the model that would be awesome! Thank you in advance!
      ~Susan
      Carcass_Std_4B_900x470x470.skp
      Respectfully,
      Susan (Moses) O'Kane
      Moo Arch / Architecture & Design
      • P
        pcmoor
        pick1.JPGHi
        To change the axis, open the component, then right click on the axis, just outside the geometry, select place, and redraw axis where required
        otherwise seems to work okay,
        Carcass_Std_4B_900x470x470 (1).skp
        • mooarchiM
          mooarchi
          Phillip:
          But of course! Lovely! Thank you SO much!
          ~Susan
          Respectfully,
